Help alternator plug??
Old Dec 1, 2012 | 04:14 PM
ConvertedFord's Avatar
ConvertedFord
I installed another alternator bit the plug in is different. It has a 3G style. How can I make this work. The harness I found at oreilly that fits has 3 wires mine has 2.
Old Dec 1, 2012 | 04:20 PM
BLADE35's Avatar
BLADE35
Ask JOSH he will know where to get the Adapter
Old Dec 1, 2012 | 04:22 PM
ConvertedFord
I have a adapter but my alternator has no where for 3rd wire center wire(white)
Old Dec 1, 2012 | 04:33 PM
JimsRebel's Avatar
JimsRebel
What year is your truck? Are you going from a 2G to a 3G ALT.
The newer voltage regulators (VR) found on the newer ALT (2G or 3G) need to have all 3 inputs to make it work.
Jim
Old Dec 1, 2012 | 04:42 PM
BLADE35's Avatar
BLADE35
Josh went 6g to 3g IIRC
is that what you did
IDK the total story what changes are from 6G to 3G
It wont charge???or just worried about the extra Wire or Battery Light On
Old Dec 1, 2012 | 04:45 PM
ConvertedFord
Soon as I hook battery to it dash lights came on and radio with no key in ignition
Old Dec 1, 2012 | 04:54 PM
BLADE35's Avatar
BLADE35
And your shure the pigtail is for a 6g to 3G Conversion
sounds like wrong pigtail
Old Dec 1, 2012 | 04:59 PM
JimsRebel's Avatar
JimsRebel
Here is a photo of the 3G VR plug.
Does it look like this?
http://store.alternatorparts.com/ima...dPlugCombo.JPG
Old Dec 1, 2012 | 05:01 PM
ConvertedFord
Ok work inning left the white wire unhooked and tied other 2 direct not adapter. Tks
BLADE35's Avatar
BLADE35
Sweet looks like you been down this road B4
thanks for the Help
Old Dec 1, 2012 | 05:06 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
The white wire circles back and clips onto the spade on the alternator and has nothing to do with the rest of the harness.
Josh
Old Dec 1, 2012 | 05:40 PM
Bullitt390's Avatar
Bullitt390
My conversion harness was purchased locally, but they are available on eBay for $12-15. Summit Racing wants a fortune for theirs, but that is an option too.
Close-up of the white wire and the connection to alternator.
A direct connection is more than adequate as well. Funny thing... you won't find a commercially available 3G to 6G conversion connector.
Josh
Old Dec 1, 2012 | 06:39 PM
ConvertedFord
Yes the white with black strip had no place to connect on my alternator so I left it unhooked n it's working fine tks
Old Dec 1, 2012 | 06:48 PM
Bullitt390's Avatar
Bullitt390
What alternator did you install then? All 3G alternators use the white wire. You didn't install a 4G did you?
Josh
Old Dec 1, 2012 | 09:36 PM
ConvertedFord
It is a 4g
