6.0 L Serious Problems...
ffice
ffice" /><o
></o
><o
> </o
>This is what they said they had to do:<o
></o
><o
> </o
>67650 FICM, fuel regulator, injectors 1.00 pulled codes KOEO-ODDTCDS P0261, PO267, PO273, PO279, CMDTCS, P, 0261 . PO263, PO267, PO270, PO273, PO276, PO279PO341, P2291, monitored PIDS found bad FICM, performed power balance injectors 1, 5, 3 dropping, REC FICM, fuel injectors, and fuel regulator, removed valve covers, oil rails, removed injectors, installed new injectors, reinstalled oil rail, and valve cover, removed air filter, removed degas bottle, removed FICM, installed new FICM, programmed FICM, reinstalled degas bottle, installed new air filter and changed fuel filters, test drove after test drive shut off vehicle to clean engine bay, when starting vehicle has long crank monitored PIDS vehicle had a oil leak hot causing a long crank while hot. <o
></o
><o
> </o
>Engine drivability, REMAN NOZZLE ASY, injectors 3.00 removed passenger side valve cover, removed high pressure oil rail, removed injectors, 1, 3, 5 installed all three new injectors and reinstalled high pressure rail, reinstalled valve cover test drove ok at this time.<o
></o
>REMAN MODULE – engine control – EEC<o
></o
>Fuel regulator 1.10 removed cold side CAC tube removed fuel regulator, installed new regulator, reinstalled CAC tube, torque to 10 Ft Lbs, ok at this time.<o
></o
>Replaced diesel fuel filter, drained water separator, changed both primary and secondary fuel filters, changed air filter<o
></o
>Replaced hot side CAC tube B connection air inlet, CA Clamp EA Clamp, CAC tube .50 removed hot side tube, removed CAC tube, installed new CAC Tube test drove ok at this time…<o
></o
>Pressure regulator, dummy plugs 3.50 shut truck off went to start vehicle has long crank while hot, pulled in bay monitored ICP, ICP Voltage, IPR, RPM, vehicle has a high pressure leak, performed high pressure leak test found both dummy plugs were leaking, installed new dummy plugs, performed high pressure leak test, no further leaks found at this time. Test drove vehicle, shut off for 5 mins vehicle start right up ok at this time.<o
></o
>End of report….that cost $3300, so far we have $4900 into this truck in the last 3 months. So after they did all this work we drove the truck for about 2 weeks, and on 7-11-12 it broke down again!<o
></o
>7-11-12 they took the truck out and got about 1 block away and the “check engine gauges” light came on…because it was over heating, so we pulled over and turned the truck off and had to tow to legacy ford. Legacy ford looked at it and said…it over heated and blew both head gaskets….they want $7800 to replace both head gaskets, and if they heads are bad now because it over heated they want another $3000 on top of that. So if we have them fix this worse case we would have almost 16,000 dollars into this truck!!!!!!!!!!!! So…what do you guys think…did they do something that might have caused this to overheat?! We want to be able to prove they are responsible for this over heating event, and they have to fix it since we just gave them $3300 to fix the previous problems…what would cause this truck to overheat like that two weeks after they fixed it?!?! Let me know what you guys think, need your help on this big time…truck is on standby until we figure out what the heck to do…<o
></o
><o
> </o
>Thank you!!<o
></o
><o
> </o
>Steve<o
></o
No tunes or mods, all stock, all guages are stock, i dont know about scanguage...
Thanks,
Steve
at some point you will have to be an owner.
just wondering how many hours are on the engine?
you can access this threw the dash.
Now, if you had told me to just fix the present issue, that's another story ......
They should of checked the cooler whit that
much work going into it. After all they do give signs.
You should take it up to Enumclaw WA Fugate Ford.
They are on highway 410 just out of Buckley WA
They do know diesels and do a good job.
You need to get some thing like the Scanguage II
Sean
Some things to consider when you are doing the head gaskets:
-check turbo for proper function so you know it is not overboosting which can blow headgaskets
-replace oil and EGR coolers because they are R and R'd anyway during the repair and can cause overheating and blown headgaskets
The scanguage is about 150 bucks and is a plugin scan tool that will give you oil temp, coolant temp, trans temp, FICM volts, battery volts, turbo vane movement, MPG, among other things. This info can be monitored and you can keep small problems from cascading into major issues like you have now.
I feel bad for you. That is a lot of money, and I hope you get it fixed right and for a fair price.
With all that being said from what I can see it looks you were chasing 2 different problems. Problem one appears to be in the fuel system (and controls) With the way they played with injectors, HPOP, and FICM. The FICM sends the control signals which allow HP oil to fire injectors and send fuel into cylinders. Problem 2 which is what the truck is down now with is a over heating.... blown gasket problem, Probably caused by the oil/egr cooler mentioned above.
I would say good luck on getting them to eat the cost of repair. I would try to price some other dealers and try to negotiate. Maybe Since you are such a "Valued Customer" they may allow you to pay labor and invoice price instead of "retail price" on parts.... you save money and the dealer doesn't lose money.
You may also want to check the other FORD dealers I have 2 in my imediate area and while they both do diesel. The truck dealer (he only does full size trucks) is much cheaper than the dealer that stocks the full line of ford prodiucts.
If you decide to get the truck repaired you may want to think about checking the threads here and make some sort of decision on how to "improve" the 6.0L so this never happens again. I would check into
1. CETANE- add a additive to fuel to boost cetane ratings
2. Blue Spring Upgrade- raise fuel pressure helps to prolong injector life
3. FICM upgrade- A few hundred dollars to mimimize impact of heat and vibration on the brains of the fuel system
4. Coolant Filter- can we say coolant breakdown and/or casting sand....
5. Head Studs verse bolts.
6. Optional (EGR delete and or BPD coolers)
ffice
ffice" /><o
></o
><o
> </o
>We just had a similar truck same model, year and engine, in the Gus Johnson Ford’s shop in Spokane, WA yesterday for $2200. It was blowing white smoke (burning coolant) we took the degas bottle cap off while it was running and smoke/vapor was coming out of the bottle. This is what they say they did:<o
></o
><o
> </o
>Cooler – EGR $391<o
></o
>Core Charge $75<o
></o
>KIT $330<o
></o
>Valve Assembly – modulator (which is probably the EGR Valve) $203<o
></o
>Anti Freeze $51<o
></o
>Hardware $5<o
></o
>Pin $5<o
></o
>15 40 w oil $50<o
></o
>Oil filter $50<o
></o
><o
> </o
>Total parts 1200<o
></o
>Labor 1008<o
></o
>Total $2208<o
></o
><o
> </o
>Dang near the same exact truck…different color…same problem…but legacy ford didn’t do anything with the EGR and a week later we are broke down again…probably for the same reason we brought it in…what do you guys think, I got to get this fixed but we cant just bite the bullet ($9800 repair for new heads and gaskets)<o
></o
