Best Fuel Additive
Old Jul 11, 2012 | 06:33 AM
sammy77's Avatar
sammy77
Cetane boost and 2 stroke oil.
Old Jul 11, 2012 | 12:27 PM
fordtruckrodder's Avatar
fordtruckrodder
Motorcraft Cetane Boost, I do notice a difference in sound since i've been using it.
Old Jul 19, 2012 | 09:52 PM
PattonC222's Avatar
PattonC222
How often should one use the additives? Every tank or every few etc..?
Old Jul 19, 2012 | 10:30 PM
Regulator1988's Avatar
Regulator1988
I think so. I do every tank when I have the cash that is
Old Jul 19, 2012 | 11:09 PM
berick's Avatar
berick
I noticed a huge difference running Stanadyne Performance Formula and switching to Amsoil API Cj-4 5w40 synthetic. The truck seems to run a lot quieter, start easier and it has a bit more get-up-and-go off the line as well as when passing on the highway. It took probably 2 fills in a row of the fuel additive but I try to add it now every second fill-up.
Old Jul 20, 2012 | 09:34 AM
Yahiko's Avatar
Yahiko
Is t winter mix of the Motorcraft stuff or do I need to be adding something with it?
Thanks
Sean
Old Jul 20, 2012 | 10:40 AM
WH 6.0's Avatar
WH 6.0
I use the Motorcraft cetane boost. Regular formula only for me,it doesn't get cold enough here in Va. to need the winter stuff. I too notice a difference in sound with the cetane boost. Quicker starts as well it seems.
Old Jul 20, 2012 | 11:07 AM
Corner Gas's Avatar
Corner Gas
I use Amsoil diesel concentrate and cetane boost. Those are the easiest for me to get arouned here.
Old Jul 21, 2012 | 07:26 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
I use a variety of them & they all stink way bad! If you buy parts from tousley depot, they have cheezit's flavor PM-22...
diamondrcattle
6.4L Power Stroke Diesel
17
Mar 7, 2014 08:21 AM
builttoughf350
6.7L Power Stroke Diesel
32
Jan 11, 2013 01:29 PM
Major Marvin
31
Sep 4, 2011 09:29 PM
Headviking
Mar 15, 2010 07:34 PM
Tasslehoff13
Feb 8, 2004 01:25 PM
