P1632
Old Jul 9, 2012 | 10:27 AM
Lobo's Avatar
Lobo
P1632
I received the code P1632 on my 2000 Expedition, with the 4.6 L engine, today. Looking up the code I am finding two different definations - Theft Deterrent Fuel Disable Signal Received and Smart alternator faults sensor / circuit malfunction. I am wondering which code is the correct one and what to do about it?
Old Jul 9, 2012 | 03:22 PM
projectSHO89's Avatar
projectSHO89
I can find no evidence that Ford ever used that DTC. Read it again.
Old Jul 10, 2012 | 07:18 AM
Lobo's Avatar
Lobo
You are right, I had the code down wrong, it is P1635. This is for - 5 Volt Reference Circuit???
Old Jul 10, 2012 | 08:19 AM
pdqford's Avatar
pdqford
Have you changed tire size, axle ratios, or PCM ?
Old Jul 10, 2012 | 11:21 AM
projectSHO89
I don't know where you're getting your code definitions, but you need to use one specifically for your vehicle when the code is above P1000.
The 00 Expy PCED says for P1635:
P1635 - Tire/Axle Ratio Out Of Acceptable Range
This Diagnostic Trouble Code (DTC) indicates the tire and axle information contained in Vehicle ID block (VID) does not match vehicle hardware.
Incorrect tire size
Incorrect axle ratio
Incorrect VID configuration parameters
Using the scan tool, view the tire and axle parameters within the VID. They must match vehicle hardware.
Note 11: The vehicle ID block (VID) needs to be reprogrammed. For instructions refer to Section 2 , Flash VID Block Procedure.
Probably dealer time....
Kevinm1980
Jan 8, 2019 12:16 PM
brainfart
1983 - 2012 Ranger & B-Series
Apr 12, 2006 08:37 PM
Goulette55
Jan 20, 2006 09:19 PM
shorthair
May 3, 2005 09:30 AM
rmarion
Sep 19, 2004 07:51 PM
