P176 doesn't look like a valid OBDII code, they're usually one alpha and four numeric, i.e. P0402, P1400. Pull the code again. you can look up the DTC at www.obdii.com
Here's some info from the OBDII web site:
P0176 = Fuel Composition Sensor Circuit (Generic OBDII Code)
P1760 = Pressure Control Solenoid A Short Circuit Intermittent (This is Ford specific OBDII Code and applies to engine code "G", Engine code is the 8th digit od the VIN)
I hope this helps.
