Weak Starter?
Old Jul 7, 2012 | 09:45 AM
clintusaf's Avatar
clintusaf
Weak Starter?
Hey guys,
My truck has been starting really slow. It has slowly went downhill for about a month now. Now it's to the point where it starts turning over really slow and sounds like you would for sure hear the click-click next, but then it slowly speeds up and starts. The batteries(2 yr old 850cc Motorcrafts) have tested good and I have checked and cleaned the terminals. I'm wondering if I should look at replacing a starter or cables. Where should i go from here?
Old Jul 7, 2012 | 10:39 AM
woodnthings's Avatar
woodnthings
The starter could be weak. Since they have a tough time turning over the high compression engine a weak starter will turn it slower. The batteries have been tested individually right and that is load tested?
Old Jul 7, 2012 | 01:26 PM
clintusaf's Avatar
clintusaf
yes, they were individually load tested.
clintusaf's Avatar
clintusaf
Ok, I crawled under the truck and found a broken starter housing bolt. They are the really long bolts that run parallel to the starter. I backed both housing bolts out to observe the inside of the starter and there was a lot of soot. I ran and got a new starter from O'rielly's Auto for $189 with a lifetime warranty. I looked at motorcraft starters and refuse to pay $450. Installed the new starter making sure to disconnect the batteries first. After installation, turns over perfect.
The new starter sounds alot different. My old starter was louder and had a kind of high pitch wine. This new one is much quieter with out the wine. Why would this be?
Old Jul 7, 2012 | 01:56 PM
SpringerPop's Avatar
SpringerPop
Adequate grease in the gear-reduction train.
Pop
Old Jul 8, 2012 | 02:36 AM
big poppa's Avatar
big poppa
I would have had your stock starter rebuilt. After a 186000 miles here and still cranking says alot for our brand and type starters. Too late but.......
heavy_d
16
Mar 21, 2014 12:21 AM
mac01
24
Nov 27, 2009 03:01 AM
97 RED PSD
Apr 22, 2006 09:32 AM
93superflare
Sep 27, 2004 09:46 PM
bobodean
Mar 16, 2003 09:04 AM
