76 F-250 Power Steering Pump Replacement
As stated I am needing to replace the ps pump on my 76 f-250 4x4. I bought a new pump and the very simple question i need to ask is this. Does the pump bolt to a bracket that is installed into the adjustment bracket that bolts to the motor? I hope that makes sense?
The pump I got from napa is just the pump and reservoir, the adjustment bracket that bolts to the motor has three holes on top and a hole on the side for the bolts and tensioner bolt.
Stupid easy question to answer I would just like to make sure i have the right parts while im a block away from the autoparts store (before I get home after they are closed). Furthermore, any tricks to getting these old *** pulleys off of the pump (other than the obvious pulley removal kit). Thanks Gents!
straightsixer
03-09-2013 12:38 PM
94' Ford
06-30-2004 08:02 AM
