oil cooler again!!!!
Old Jul 3, 2012 | 05:46 PM
BLADE35's Avatar
BLADE35
Originally Posted by Mich6.0
Change the sensor it is the cheepest and easy to get at, what can it hurt. And if you clogged another cooler switch to ELC and avoid the silicant problem , Did I see some where on another blogg that Ford is putting a core charge on the oil cooler ? Is that there way of avoiding a law suite for what should be a recall item.
Usually things have a Core Charge if its going to be rebuilt
the problem with having a oil cooler recall is an OIL Cooler isnt a saftey Item Ford would have to do it out the Goodness of there HEARTS LOL
Old Jul 3, 2012 | 07:17 PM
bismic's Avatar
bismic
The oil cooler is not the problem. The Gold isn't either really - not by itself. There are many people making the Gold work with proper maintenance and assuming no other engine problems (like leaking head gaskets, ccolant leaks that drop coolant levels, weak coolant concentrations, mixing incompatible fluids, etc).
Chemistry simply does not change and if it works for some, it will work for everyone unless a failure of some kind is introduced. A knowledgeable water treating person on another forum has duplicated the gelling based on weak additive strength and excess heat (not silicates, but acetal polymers from glycol breakdown). That being said, Tex25025 has a TON of power, functioning EGR systems, OEM EGR cooler and oil cooler, and uses the Gold successfully. Chemistry can be the same for us as it is for him. It is not the terrible culprit (by itself) that it is blamed for.
The Gold is not robust - I definitely agree with that! Maybe ELC is more robust, but I have seen two cases of it gelling, so it is not perfect either.
That being said, ELC is a cheaper answer than an external oil cooler (and less maintenance than Gold).
Old Jul 3, 2012 | 09:21 PM
WSS's Avatar
WSS
Originally Posted by bismic
Post a link to the external oil cooler you purchased.
Where does it get its oil flow from?
Also, do you still have an EGR system?
It has a housing that fits on the (previous) oil cooler location and blocks it off (I think). The hoses to the OE cooler come from the new oil filter cap/housing, it has a billet mount/housing as well. EGR, negative. The round cooler was probably 70% plugged but not cracked or broken. I'll keep it just in case. I am working slowly on it right now, should have it buttoned up by first of next week, I'll post some results when it's all done. I have a SGII now and will be able to see what is happening.
IPR External Oil Cooler Kit for Ford 6.0 Powerstroke
WSS
Old Jul 3, 2012 | 10:36 PM
BLADE35's Avatar
BLADE35
I agree Mark its not the OIL cooler
But a Combination of alot of things
ELC seams to be Great for me so far OIl Cooler staying the same spread as when I installed it I also put the ELC in at the same time as the oil cooler
I did have a chance to run coolant filters with BOTH ELC & Gold
the Coolant filters with the ELC have been going further and I have always changed the same when Coolant filter return line dont get HOT like the supply side does
I never did see anything in the Gold Filters that Obviously plugged them In fact I saw nothing in the gold filters but they shure was clogged
Old Jul 5, 2012 | 12:23 AM
SHOOTER22250's Avatar
SHOOTER22250
Put a coolant filter on it now before you do anything else and drive it a while to clean up the system before you even think about putting a new oil cooler on it.
If not you will plug the new one up and be in the same boat you are in now.
Keep monitoring the ECT/EOT while the filter is doing it's thing.
Replace the EOT sensor and see if it could be the culprit, if the reading are close to the same switch the ECT and the EOT sensors as I believe they are the same sensor and compare the reading.
Were you driving at the recommended speed and with no load (trailer or load in the bed) on the engine when you got the readings?
I could be wrong, but with those kind of outside temperatures and given the fact there is such poor air circulation under the hood of these trucks it may just be a case of not enough air circulation. The first day it cools down to around 90 to 95 look at again as see what your readings are.
Macrosill
Jul 17, 2019 01:02 PM
wisevoss
Jan 29, 2014 04:51 PM
fatcowvtx
Dec 6, 2010 05:44 AM
FordMan35
May 4, 2010 10:22 PM
Gage2502
Modular V10 (6.8l)
Feb 23, 2006 03:00 PM
