Bullet proof oil cooler temps
Have a 2006 F-250 with a bullet proof EGR cooler, 125,000 miles, second oil cooler, edge insight gauges Other than that its all stock.
My OEM oil cooler had an oil leak in the cooler and made the coolant into a nice oil sludge.
Decided to go with the bullet proof oil cooler installed by a reputable local diesel shop.
With the stock oil cooler I was seeing oil temps around 211 while empty. With the new bullet proof oil cooler I'm seeing oil temp around 215-218 and when hauling a light 16 foot flatbed trailer and a dune buggy (maybe 3K) Im getting up into the high 230 temps while going through the hills. All outside temps 70-80 degrees.
My questions is what are others with Bullet Proof oil coolers seeing in oil temps while empty and towing.
Thanks in Advance
Thanks in Advance
I have the BPD condenser mounted external oil cooler, without the cold-weather package.
I have a tough time getting my oil temps to 190 w/o using the A/C, so you should certainly NOT have oil temps that high based on your situation(s).
Have you verified your oil level? It's possible they added 15 qts and didn't follow the directions to pre-fill the oil cooler & filter? thus you aren't pumping any oil through the cooler?
good luck!
good luck!
Is that even possible? Is the BPD kit a bypass cooler? I was under the assumption the low pressure oil had to go through the cooler. If not then there would be unfiltered oil circulating in the system
Thanks for the quick replies.
TexasTech-Don't have the cold weather package. I live in San Diego, no need for it.
npccpartsman-checked the Temps this morning and oil and water temp are within 1 degree
Misky 6.0- I also have the condenser mounted external oil cooler. I'll double check oil levels and see if external oil filter is getting warm after driving.
Misky-what are your temps when towing level and up a grade?
Thanks again guys
Thanks again guys
Thanks again guys
Thanks again guys
Did you get the factory filter or the remote filter? The BPD isn't a bypass cooler. All the oil goes through just like the factory cooler.
The stock setup actually bypasses a lot of Oil I can see it each time I go WOT and temps shoot up a few degrees shortly after
Does the BPD setup have anything like that??
I know it bypasses oil if you have the cold weather kit and even with that it's not a full bypass. With a remote filter nothing in the factory filter housing is used.
