Modular V10 (6.8l)
Oil cooler
Old Feb 22, 2006 | 10:37 AM
Gage2502's Avatar
Gage2502
Oil cooler
On the 2005 Superduty V-10 Iam going to install the oil temp gauge,
should I install the sender where the factory oil pressure sender is, I was going to install a T fitting there, or should I install it using a T-fitting going to the engine oil cooler?
The engine oil cooler is the smaller cooler behind the front bumper right?
What do you think?
Old Feb 22, 2006 | 10:41 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Isn't the oil cooler like the pre-05 V10's, where coolant is routed to the oil filter adapter, and engine oil is NOT routed to a seperate cooler up front?
Fred? Cap? Wrench? SOMEONE with an '05 ???
Old Feb 22, 2006 | 10:42 AM
ford390gashog's Avatar
ford390gashog
if you use a T for a temp reading it will be way off. you need flow to get temp. the oil cooler is simply 2 coolant hoses going into a adapter. the oil never goes to a external cooler.
Old Feb 22, 2006 | 07:42 PM
fordfan428's Avatar
fordfan428
"The engine oil cooler is the smaller cooler behind the front bumper right?"..Are you sure that isn't the trany cooler?..
Old Feb 22, 2006 | 07:48 PM
T- Squared's Avatar
T- Squared
The little cooler in the very front is the power steering cooler...at least it is on my '01. The tranny cooler is between the A/C condenser and the radiator....again, on my '01.
Old Feb 22, 2006 | 08:51 PM
krewat's Avatar
krewat
Mine too
Old Feb 22, 2006 | 11:22 PM
fordfan428's Avatar
fordfan428
LOL..Well since my is an 01 also then I guess it is the P/S cooler..Next time I am under there changing the oil I have going to have to pay more attention..LOL..
Hey krewat can I borrow this "I've been wrong before, I'll be wrong again. Just wait and see"..LOL..
Old Feb 23, 2006 | 12:57 PM
rwetter's Avatar
rwetter
Soo... Is there another port hole on the V10 one could use to get an accurate Oil Temp?
Old Feb 23, 2006 | 01:08 PM
krewat's Avatar
krewat
Before anyone else replies, I've read here that the best place is in the oil pan. But that's not really possible without removing the pan and having a bung welded into it.
Guys?
Old Feb 23, 2006 | 03:00 PM
rwetter's Avatar
rwetter
Yes the oil pan would be nice, but not easily feasible! I did read about some of the plugs/ports on the front of the engine
See:
https://www.ford-trucks.com/forums/s...d.php?t=463425
But A picture would help!
I also replied to Captchas in that thread...
