Oil Pan Replacement
Old Jul 2, 2012 | 04:31 PM
kurtdc's Avatar
kurtdc
Oil Pan Replacement
I have a 97F250 with a 351 Windsor engine. I finally managed to get all the bolts out of the oil pan but can not manage to manuver the pan enough to remove it from the truck and replace it with the new one. Does anyone have any suggestions or ideas to help. Also how long can I leave the engine without oil in it when not running at all???
Old Jul 2, 2012 | 06:38 PM
redford's Avatar
redford
FTE Leadership Emeritus
You can't leave it long, things will rust. Like, put it back on until you are ready to take it off and replace it.
You will probably have to lift the engine up to replace the pan.
Old Jul 2, 2012 | 08:28 PM
Tom's Avatar
Tom
Hi Kurt, sorry to hear about your troubles. I going to move this to the '87-96 F-series forum because they also cover your '97 F250 HD. You should get some more responses down there.
Old Jul 2, 2012 | 09:00 PM
05victorylly's Avatar
05victorylly
I have read that with the small blocks you can unbolt the motor mounts and get the motor jacked up high enough to get it past the cross member. Good luck, I am sure someone who has done it on a 351 will chime in soon!
I am about to do this on my 460, but I am pulling the motor.
Old Jul 2, 2012 | 09:07 PM
kd0axs's Avatar
kd0axs
I was able to do this with my 300, pretty sure it can be done with the V-8s too.
Old Jul 2, 2012 | 09:51 PM
redlightning93's Avatar
redlightning93
Although not a FTE thread, this is the most informative article on Oil Pan Replacement I have seen:
Oil Pan+Pump Replacment (56K Warrning!) - FSB Forums
Good Luck!
Old Jul 3, 2012 | 06:33 AM
Xclimation's Avatar
Xclimation
That is a great write up with pics. But I'm not so sure our pan comes out that easy. You may have to remove the intake manifold to get the engine a little higher up. Try it without removing the IM first and see if you can get it out. Let us know if you were able to do it without taking off the IM.
Good Luck!
Old Jul 3, 2012 | 06:54 AM
kurtdc's Avatar
kurtdc
thanks for all the help guys think im gna try to jack up the engine a bit and hopefully get it replaced
mamajan
May 4, 2006 09:48 PM
broncofrk
Bronco II
Dec 24, 2004 04:46 PM
Bronco Bill
1978 - 1996 Big Bronco
Apr 25, 2004 09:28 PM
kjett
35
Feb 6, 2004 12:54 PM
cjben
Aug 3, 2002 03:58 PM
