Bronco II Ford Bronco II
oil pan removal
Old Dec 21, 2004 | 08:59 PM
broncofrk's Avatar
broncofrk
oil pan removal
I have a 1985 broncoII and i need to replace the oil pan, i tried jackin it up by the oil pan and putting blocks between the mounts, cant get enough clearance any ideas?
Old Dec 21, 2004 | 11:08 PM
Monty06's Avatar
Monty06
lift out engine your not going get it out without lifting the engine if you do manage to do it i would like to see how you managed but otherwise your wasting your time.
Old Dec 22, 2004 | 10:01 AM
7Yellow3's Avatar
7Yellow3
Yeah, I just went through the same thing. I had to disconnect the exhaust and the transmission and hoist the engine up a good six inches or so before the pan would come out. Broke all four bolts on the Y-pipe while I was at it. What fun!
Old Dec 22, 2004 | 01:54 PM
broncofrk's Avatar
broncofrk
I think im going to cry, How do you disconnect the transmisson and where do you hook up the chains on the motor
Old Dec 22, 2004 | 01:56 PM
broncofrk's Avatar
broncofrk
and do i have to disconnect anything else to lift the motor
Old Dec 23, 2004 | 12:49 AM
Monty06's Avatar
Monty06
just remember frame crossmember underneath trans
i had to losen it slighty to lift engine. also rad lines for cooling trans be carefull
Old Dec 24, 2004 | 12:07 AM
dirtybroncoii's Avatar
dirtybroncoii
I was told it would be easer to just remove the entire engine to do something like that.
Old Dec 24, 2004 | 12:39 AM
Monty06's Avatar
Monty06
disconnect tranny and just lift out engine is possible but not needed you still have about 1ft of clearance between the upper part of trans and the flooring enough to level the engine and take out the oil pan if you have the money i would try to put in a new oil pump and screen while your down there but that's my opinion.
Old Dec 24, 2004 | 04:13 PM
steve381's Avatar
steve381
tried that project on my 88 b2 without much succes but i had limited tools to work with if you can get the suspention to hang and the motor up high enuf the repair books say it can be done without actually removing the engine. i agree with monty06 do the pump and screen while your at it save yourself a headache in the future
Old Dec 24, 2004 | 04:46 PM
broncofrk's Avatar
broncofrk
Im tryin to jack up the motor from the oil pan and the motor seems to be coming up in front but not the back where the oil pan is
