blue Spring
Old Jan 3, 2012 | 12:50 PM
GeneLaw1's Avatar
GeneLaw1
blue Spring
Gentleman,
What are the benefits of the "Blue Spring update"?
Cheers,
Gene
Old Jan 3, 2012 | 12:51 PM
w_huisman's Avatar
w_huisman
Approximately 10psi more fuel pressure. Less of a chance of low fuel pressures taking out injectors.
Old Jan 3, 2012 | 01:09 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
The replacement fuel pressure regulator puts the fuel pressure back into the correct range spec'd for the injectors. It's not an "upgrade" or "update" in my mind, it's the fix for the problem of low fuel pressure.
To check the fuel pressure, install a fuel pressure gauge/sending unit into the secondary fuel filter bowl (or into a replacement cover) and check the pressure at idle, normal driving, and at WOT. I was idling around 50psi, and was dropping to 40psi at WOT. With the new regulator installed, I run about 62psi at idle and drop to just over 50psi at WOT.
Old Jan 3, 2012 | 01:11 PM
GeneLaw1's Avatar
GeneLaw1
OK, sounds excellent. I had a blue spring installed couple weeks ago (out of necessity due to a leaking cap), just wondering the difference.
Old Jan 3, 2012 | 02:02 PM
hasteranger's Avatar
hasteranger
It is a ford "revised" part. Ford revises a part when there was something wrong with the old one and the new part fixes it. Basically there way of saying "we aren't admitting that we made the old one wrong. We are just saying we found a way to make it better."
lol
Old Jan 4, 2012 | 02:58 PM
GeneLaw1's Avatar
GeneLaw1
lol
Ah, and of course, charging you for it all at the same time. Sounds like capitalism, lol
tofargone
Dec 16, 2019 12:45 PM
95PSDieselP
Jun 17, 2012 06:41 PM
dan.alger
Apr 9, 2011 06:55 AM
UNTAMND
Aug 17, 2009 10:14 AM
deetown
Mar 20, 2007 09:29 PM
