bellows up pipes
Old Jun 30, 2012 | 10:30 AM
luvemhot's Avatar
luvemhot
bellows up pipes
I had to remove the bellows up pipes that i had put in. When I did it I had a bolt break off in the collector. Tried to easy out it and failed. Can I use the old collector?
Thanks for your help
Old Jun 30, 2012 | 10:37 AM
HD Rider's Avatar
HD Rider
I'm not sure if you can use the old collector but you should be able to take yours to a local machine shop to have it professionally removed/repaired.
Old Jun 30, 2012 | 10:46 AM
luvemhot's Avatar
luvemhot
I was going to do that just needing to get my truck back together. then replace it back later next time I have it apart
Old Jun 30, 2012 | 11:52 AM
woodnthings's Avatar
woodnthings
I am pretty sure it won't work for you, they are different. Best bet is o remove the collector and get the bolt out. Once it is removed you will be able to re-drill the hole and you may e able to re- tap it too. Worst case, drill it oversized and use a helicoil or thread insert.
Old Jun 30, 2012 | 11:54 AM
luvemhot's Avatar
luvemhot
thanks guys
JWA
Modular V8 (4.6L, 5.4L)
Jul 8, 2019 07:37 AM
mdr617
Dec 16, 2010 11:07 PM
seawulff
34
Jan 8, 2006 02:07 AM
desperado_18_2000
General Automotive Discussion
Apr 5, 2005 03:53 PM
jpb222
Sep 30, 2002 08:26 PM
