air in fuel - trying to get home
2008 6.4 Changed fuel filters,problems starting,with key on off deal. Finally started, sounded great, 30-40 boost. Ran 5 miles,ck engine lite came on and slowed to 25 mph, then 45, then 60 with little power 20 psi boost. Did this once before,dealer said air in lines,charged $80. Read here to bleed high and low lines. Did this the messy way 2 times. Bleed low with running, high with key. Should this work ?? Should I have to clear code or will it go off driving if air out?? Thanks for any help,out of town trying to get home.
Code should go away after while when all the air is out. At least that is what I recall. I had this happen one time.
It will stay in the history so if you take the truck in later for work they may see it and you will have to tell them to ignore it.
Sounds like a code reader would be very helpful to you. Seems to me that by now you should have all the air out. Wonder if something else is going on as well.
P0088 - Fuel Rail/System Pressure - Too High
Description: The powertrain control module (PCM) regulates the fuel rail pressure by controlling the fuel volume control valve and fuel pressure control valve. When the PCM is no longer capable of maintaining the fuel pressure the DTC is set.
Possible Causes: Fuel pressure control valve stuck closed
Fuel rail pressure (FRP) sensor
Diagnostic Aids: Use the high pressure fuel injection pump 4-pin inline connector to diagnose the fuel volume control valve and fuel pressure control valve.
Application Key On Engine Off Key On Engine Running Continuous Memory
All GO to Pinpoint Test M .
