79 351M into 96' bronco
Hey everyone,
I have a 96' Bronco XLT with the "high end" 351W in it (or so I'm told).
I have the truck up for sale and its been a few months and I've been looking around for a new truck and I found a 79 bronco with a 351M in it for $450.
If my truck doesn't sell shortly I've been thinking of buying the 79' and swapping the whole drive train (engine, trans, t-case, maybe rear axle) into my 96. Besides rewiring most of the truck what kind of major issues will I come across i.e. motor mounts differ.
96' Specs: 351W (tow package w/ oil cooler), e40d trans, BW 1356 t-case. Dana 44 TTB (4.10 gears), Ford 8.8 (4.10 gears), 33x12.50x15 tires.
79' specs: 351M, c6 trans, np205 t-case, Solid Dana 44 front, Ford 9 rear. Stock everything.
Since I can really only afford to have one truck (and I'd rather have the 79) I figure I'll just make the most of both.
Received 3,147 Likes
on
"Big Block"? The 351m might have a tall deck, but it is pathetic in stock form for power. 132-137 hp vs. 205; 242-257 torque vs. 328? (vs. a '96 EFI 351w)
I'd rather have the 300 six than a stock 351m.
Engine_Specifications
on
Crank, pistons, cam & springs, intake, carb--childs play.....
on
I don't think it'd be worth the effort to even try. Sure it'd be unique but as mentioned, you'd have no real power in stock form and it gets horrible MPG. Why not carb the 351 if you want an old school feel. Tho being a 96 almost everything runs on the computer....which would hate the carb
Does yours rev past 3500? My grandfarter had one in a LTDII and it shifted at 3500 at WOT.... It went over 250,000 miles in the careless, abusive hands of my sister then by brother after we took it away from "park by braille, stop on the freeway to check directions.." granpa.
I thought the 351m had more power the that. Wow. Well I think I'm just gunna rebuild the Windsor.
I'm aiming for around 400 hp (hopefully) but not looking to spend more $2,000. So far i think I'm going to go with
-mustang H.O. cam
-bore .030 over (stock rebuild kit from summit)
-gt40 or afr185s (or other suggestions welcome)
Truck already has long tube headers, k&n air filter, msd performance plugs and wires, and 4.10 gears
-mustang H.O. cam
on
-mustang H.O. cam
-mustang H.O. cam
Chris Adkins
08-22-2017 01:46 PM
