No Fuel??
Old Jun 29, 2012 | 05:35 PM
waterdawg69's Avatar
waterdawg69
No Fuel??
I gat a 1979 ford F-150 302 with motorcraft 2150. i the truck was running ok , but took of carb and rebuilt put it back on it fired up then died. The truck would not start back, i think it was flooding out. so i took the carb back off to check everything and put back on. Now the carb float bowl is not filling up i cranked it over a bunch and no go. so i took fuel filter off and tried again and nothing. can anyone help with this issue....
has new
plugs
wires
coil
fuel filter
fuel pump
Old Jun 29, 2012 | 06:24 PM
Pickupmanx2's Avatar
Pickupmanx2
Did you check the fuel gauge,,,,, hate to say it,, but happened to me once,, truck was on a slight incline,,,
Old Jun 29, 2012 | 06:41 PM
waterdawg69
yeah has half a tank. it was flooding before i took carb back off. and the truck has not moved since.
Old Jun 29, 2012 | 06:55 PM
4x4 Bart's Avatar
4x4 Bart
You need to check the float again and make sure it is not binding or touching the side walls or the needle could be stuck in the seat. Check it for damage and correct fuel level adjustment.
Old Jun 29, 2012 | 07:03 PM
waterdawg69
i disconnected fuel line at carb all together with filter off and cranked motor for a few seconds twice and no fuel comming out
Old Jun 29, 2012 | 07:06 PM
PRIMERED79 SHORT BED's Avatar
I know when i rebuilt my 2150, some how the needle was stuck open, so when the truck was running, i had gas pouring out of the vent tubes like mad.
I tapped on the side of the carb, and that seemed to set it straight.
You might want to make sure your fuel pump is working as well.
Old Jun 29, 2012 | 08:27 PM
Blue and White's Avatar
Blue and White
Sometimes old rubber fuel lines can get very soft after soaking in gas for a while... almost like they were made out of cellophane. The fuel pump can suck them shut. I'd check/replace every inch of rubber fuel line.
Old Jun 30, 2012 | 05:23 PM
waterdawg69
Thanks guys for all the information. found out it was fuel pump. now another problem. the threaded part of the fuel pump is now leaking fuel. its the Return line on the fuel pump. cna i just use a rubber hose or do i need the metal one. i tryed to get one but they dont have anything that will it other than rubber hose. thanks
Old Jun 30, 2012 | 10:38 PM
Return line on the fuel pump?
You should have one coming in ( from the frame) then one coming out, running up to the carb.
I don't think there is a return line. Unless I'm misunderstanding you.
Old Jul 1, 2012 | 07:02 AM
waterdawg69
sorry about that but yes its the outlet to carb
Old Jul 1, 2012 | 07:23 AM
jim collins's Avatar
jim collins
Rubber hose is okay,i always change mine to that,have been for years. I do put a fuel filter before and after the fuel pump. I haven't had any fuel deliver problems for years unless a pump dies on me.
Old Jul 1, 2012 | 09:41 AM
waterdawg69
How did u route your line do i need to keep away from motor so it dont get hot
JB78f150
May 17, 2013 08:40 PM
tomf100
Dec 9, 2012 11:02 AM
jeffreysw
21
Aug 15, 2011 08:56 PM
Reed_50
Oct 14, 2009 08:45 PM
richardmb
Aug 16, 2003 01:28 AM
