Help, engine problem
Old Aug 15, 2003 | 09:00 AM
richardmb's Avatar
richardmb
Hi All,
I have a 76 f-150 with a 302, the other day i was carring a load which had the back end sagging a little, as i was going up a fairly steep hill the truck started to backfire through the carb and loose power.
Its done the same thing twice since. Always on a steep grade...
As soon as i hit the top of the hill, it ran like a champ....
the mechanical fuel pump on the block is new.
the carb is almost new.
Any ideas on things for me to check would be very appreciated.
Thanks
Old Aug 15, 2003 | 10:02 AM
beartracks's Avatar
beartracks
Fuel filter?
Carb float level?
Old plug wires?
Old Aug 15, 2003 | 10:41 AM
jamessl1's Avatar
jamessl1
On a real steep grade with the truck loaded down and high float level in the bowl. Fuel might be flowing out of the overflow tube and straight down the carb. if this is the case, adjusting your float may correct it. There are some new carbs on the market that have the overflow tubes connected so the fuel flows from one bowl to the other rather than straight down the carb.
Old Aug 16, 2003 | 01:28 AM
buckawanga's Avatar
buckawanga
did you check your fuel gauge? on a steep hill with a heavy load most of your fuel would flow to the back of the tank possibly causing a lack of redily available fuel for the engine! just a thought.
BGrizzle89
Apr 7, 2012 05:00 PM
fordinmudd
Aug 20, 2010 03:57 AM
tom in las vegas
Nov 19, 2004 09:18 PM
motorhomenut
Nov 19, 2003 12:45 PM
jeepin_ford
Jul 3, 2003 07:17 PM
