2012 Altenator Question
Old Jun 29, 2012 | 09:51 AM
mhatlen's Avatar
mhatlen
2006 Bullet-Riddled 6.0
I have a 2012 dually with a 190 amp alt on it: alt is the same as my 06 plugs and all but notice the center wire is being used at the voltage regulator plug on 2012 alt.(3 wires 2012) (2 wires 2006)
Are they interchangeable. ? ?
Old Jun 29, 2012 | 10:03 AM
jasfaa's Avatar
jasfaa
If you can figure out if they are the same part number then they probably are. With all of the electronics on the newer truck, I would have to believe they would be different just to support all of the newer electronics but who knows.
Old Jun 29, 2012 | 10:23 AM
m-chan68's Avatar
m-chan68
A 2012 dually what? What engine?
Old Jun 29, 2012 | 10:39 AM
mhatlen's Avatar
mhatlen
6.2 litre cab and chassis
Old Jun 29, 2012 | 11:01 AM
69cj's Avatar
69cj
You are in the 6.0 diesel orum.
Old Jun 29, 2012 | 11:06 AM
m-chan68's Avatar
m-chan68
All diesel engine alternators use an internal stator circuit while gas engines use an external stator circuit. This is why you'll have only the light green with red stripe wire and orange with light blue stripe wires on the diesel engine alternators, while gas engines will have the two plus a white wire with black stripe (the 'S' circuit). But in answer to your question, no the two are not interchangeable.
Old Jun 29, 2012 | 11:15 AM
mhatlen's Avatar
mhatlen
This is the forum with the wizards, and thats a fact. It is bolted to a 6.0
Old Jun 29, 2012 | 12:30 PM
mhatlen's Avatar
mhatlen
Ok, dammit,thanks again Mike. I was hoping that you were going to see this post only wished your answer was going to be a different one. Thanks again reps coming when allowed...............
Old Jun 29, 2012 | 02:50 PM
69cj's Avatar
69cj
I agree, this is the best forum that I've found for both knowledge and good people.
Old Jun 29, 2012 | 10:02 PM
metmop's Avatar
metmop
I not sure if I am a wizard.... but seems to me that owning my truck long enough and I may become one Hehe I just figured out how to install a sinister coolant filter kit. Hopefully the hundred miles between the egc/oil cooler replacement and the installation of the filter didn't allow to much crap to clog my coolers.
One Sock
Electrical Systems/Wiring
Oct 2, 2024 01:41 PM
raerjim
Aug 17, 2009 06:47 AM
kpallagi
Jan 12, 2005 09:20 AM
crazed87bronco
1978 - 1996 Big Bronco
Feb 20, 2004 06:01 PM
signproz
Apr 26, 2001 11:06 PM
