Excursion changes per year-V10
Old Jul 6, 2012 | 01:34 PM
  #46
Stewart_H's Avatar
Stewart_H
Stewart
Old May 5, 2013 | 11:38 AM
  #47
Dogmann's Avatar
Dogmann
Found a 2002 with 45,000
Miles. Not leather but it's so
Low mile I have to consider it. How were the 2002's?
Spark Plug problem?
Trans?
Old May 5, 2013 | 12:20 PM
  #48
EXv10's Avatar
EXv10
Originally Posted by aortizexcursion
The Excursion never got the 3 valve Triton engines.
As far I know, the V10s aren't known for spitting spark plugs like the 4.6 and 5.4 are.
2001 had issues with a Transmission diode but they were recalled and by now, most of them have probably already been repaired.
The V10 was the worst offender of spitting plugs.
Old May 5, 2013 | 12:22 PM
  #49
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
02's are great! thats the year they changed the headlights, gauge clusters..other few small odds and ends. i love my '02!
  #50
EXv10's Avatar
EXv10
Originally Posted by wallz
The 05 engine got the 3 valve compared to the 2 valve in the earlier years. I think another change were the spark plug threads, somewhere in 02. They added a few more as there were a few spitting out some of the plugs.
I think there was a diode change in 02 also, in the tranny, or was that the 7.3 tranny. Hmm?
Some say it got the 3 valve and some don't, which is it?
Old May 5, 2013 | 12:25 PM
  #51
EXv10's Avatar
EXv10
Originally Posted by Dogmann
So what's the cure for the spark plug short thread
Problem??
Don't get them too tight or too loose, there is a fine line between the two because of the tapered seats with no gasket.
  #52
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
personal experience tells me the 5.4 v8 was the worst. my '98 blew one and i caught the second right before it went. 2 other friends also have blown plugs on there 5.4's. now i've had 3 V10s and know of 4 others that own them and have for a period of time. no plug spitting w/the V10's. now i know they all do it..but i have heard and seen way more V8's blowing them.
the excursion NEVER got the 3 valve motors. or coil front springs on the 4x4's. like the super dutys did in '05.
Old May 5, 2013 | 12:26 PM
  #53
Stewart_H's Avatar
Stewart_H
No more or less worse than the 5.4 or the 4.6.
Stewart
  #54
EXv10's Avatar
EXv10
Originally Posted by jh818
Tow rating on the 2000 was a bit lower than subsequent years due to the size of the bolts used.
High grade bolts should cure that.
  #55
gr8scott72's Avatar
gr8scott72
Never got the 3 valve.
Old May 5, 2013 | 12:27 PM
  #56
EXv10's Avatar
EXv10
Was this a recall? Will FORD replace for free?
I doubt it very much.
Old May 5, 2013 | 12:30 PM
  #57
EXv10's Avatar
EXv10
What's the emergency procedure when in the middle of now where and you blow a spark plug!???
Disconnect the injection and put your ear plugs in until to get to the proper place. The sound is only that; a sound.
Old May 5, 2013 | 12:34 PM
  #58
EXv10's Avatar
EXv10
As far as blowing out a spark plug I found this video-
Replacing blown out spark plug - YouTube
But then I found the time sert
+ TIME-SERT + Spark plug thread repair, Thread repair system, spark plug repair - YouTube
What plug repair kit do you guys reccomend and like?
Mainly don't use a helicoil or you'll be sorry.
Old May 5, 2013 | 12:36 PM
  #59
EXv10's Avatar
EXv10
Originally Posted by Snowseeker
I wish ford would stop using taper seat plugs! 1950's technology.
The 04-05 X didn't get the 5R100? I thought in 03 ford switched all super dutys and X's over to the 5R100?
They are OK unless you don't get them the right tightness.
Old May 5, 2013 | 12:38 PM
  #60
EXv10's Avatar
EXv10
Originally Posted by AlaskanEx
i noticed the difference in the y-pipe on my old '00 compared to my '02 and '04. debated on taking the one off the 00 and putting it on the 02 but dunno if its worth it.
I doubt it very much, you might as well go to headers.
