Excursion changes per year-V10
Old Jun 27, 2012 | 10:22 PM
  #31
ComputerCowboy's Avatar
ComputerCowboy
Originally Posted by AlaskanEx
i noticed the difference in the y-pipe on my old '00 compared to my '02 and '04. debated on taking the one off the 00 and putting it on the 02 but dunno if its worth it.
I think both designs suck
Old Jun 28, 2012 | 12:26 PM
  #32
xtshawytscha's Avatar
xtshawytscha
I am also looking at a 2000 v10. Can the manifold bolts be replaced wth better ones before they break? I would rather spend some money now than get stranded with my wife and kids on the side of the road somewhere. I'm not very mechanical so the idea of fixing anything on the side of the road is a scary thought for me! Also wondering about the best brand for the plug inserts and how much they cost for a complete set.
Old Jun 28, 2012 | 12:59 PM
  #33
ComputerCowboy
That is a great question, there are two answers.
  1. I've heard of better stainless steel manifold studs... but I don't know where to get them. That should solve the problem, the reason the stock ones break is they rust and all that heat expansion and whatnot makes them break.
  2. You won't get stranded on account of broken manifold studs, it won't really have much impact at all. It will just get progressively noisier from the area where the stud or studs are broken. You can litterally drive thousands of miles with broken manifold studs.
Old Jun 28, 2012 | 01:09 PM
  #34
Dogmann's Avatar
Dogmann
What about a blown spark plug or two. Can you drive for a hundreds of miles til you limp home to fix it?
Old Jun 28, 2012 | 01:21 PM
  #35
xtshawytscha
Thanks! That's good to know. Sounds like I can just replace them with better ones when and if they break.
Old Jun 28, 2012 | 01:22 PM
  #36
Kdr358's Avatar
Kdr358
I don't think you can go hundreds of miles without doing damage remember that cylender is dead so your dragging the weight of the piston, pulling and pushing on it without the aid of spark or fuel. I wouldn't lose sleep over the plug issue, just follow the proper tsb and torque values and only use auto lite or motorcraft plugs. I used to think that that whole torque thing was stupid but in my old v10 I spit the #10 plug.. That day I bought a timsert kit and a small torque wrench and no problems ever since! I put about 20,000 miles on that before I sold it. Lesson learned, torque values are very important with aluminum heads!
Old Jun 28, 2012 | 01:39 PM
  #37
Monsta's Avatar
Monsta
Sit. Stay.
Actually a blown plug will not stop the flow of fuel. So running the engine at all will allow fuel vapor to be pushed into the engine compartment thereby creating the risk of fire.
Blow a plug = turn it off.
But then again... ... folks are free to make any choice they desire.
Old Jun 28, 2012 | 02:44 PM
  #38
AndrewWV's Avatar
AndrewWV
Even if you unplug the injector as suggested previously?
Originally Posted by aortizexcursion
Even if a plug were to blow, one could limp the vehicle to a safe location. The engine will run albeit down one cylinder. Just be sure to unplug the fuel injector to the wounded cylinder.
Old Jun 28, 2012 | 10:24 PM
  #39
Monsta's Avatar
Monsta
Sit. Stay.
Oops, I didn't see the other post. I was quoting the post above me.
Old Jun 28, 2012 | 10:30 PM
  #40
AndrewWV's Avatar
AndrewWV
Oops, I didn't see the other post.<img src="http://images.ford-trucks.com/forums/images/smilies2/stretch.gif" border="0" alt="" title="Warped Smile" smilieid="48" class="inlineimg" /> I was quoting the post above me. <img src="http://images.ford-trucks.com/forums/images/smilies/happy0161.gif" border="0" alt="" title="Smilie" smilieid="1" class="inlineimg" />
<br />
<br />
Ok. I wondered if you had missed it or if you were saying there was still a way for fuel to get into the dead cylinder.
Old Jun 29, 2012 | 06:34 AM
  #41
gr8scott72's Avatar
gr8scott72
2001 had issues with a Transmission diode but they were recalled and by now, most of them have probably already been repaired.
Diode problem was diesel engines only.
Old Jun 29, 2012 | 07:19 AM
  #42
Snowseeker's Avatar
Snowseeker
To be fair, the burning truck could be the result of fords cruise control/brake switch which they have had recalls on since the early 90's but still continue to put the same switch in the same spot...
Old Jun 29, 2012 | 01:53 PM
  #43
aortizexcursion's Avatar
aortizexcursion
My Excursion was nearly a victim of that issue...caught it while it was smoldering and unplugged it.
Old Jun 30, 2012 | 03:18 AM
  #44
Monsta's Avatar
Monsta
Sit. Stay.
To be fair...
To be fair, I posted the first "burning truck" image that came up on Google. That is was a Super Duty was a bonus.
Old Jul 6, 2012 | 12:38 PM
  #45
Dogmann's Avatar
Dogmann
What year did Ford change the heads to accomodate the longer spark plug threads...?
