Electrical issues
Old Jun 25, 2012 | 08:05 PM
va150's Avatar
va150
Electrical issues
Need some help diagnosing an electrical issue. The truck is a 90 F150 4.9. Right now there is no power to the truck. The battery is fully charged. I replaced the starter solenoid and power was restored until I engaged the starter which fried another solenoid. Could it be the starter? Thanks.
Old Jun 26, 2012 | 12:03 AM
ford2go's Avatar
ford2go
It certainly COULD be the starter -- or a short in the wiring.
Check the wire to the starter with a good meter -- there's probably a spec for the resistance somewhere-- but it will be pretty low.
Would be worthwhile to take the wire off at the starter and check with a meter to see if it's shorted to ground.
One more thing to think about -- is the starter stuck ( motor frozen or just jammed). I don't know if a stuck starter would blow the solenoid -- but it might.
Good Luck,
hj
Old Jun 28, 2012 | 10:09 PM
va150's Avatar
va150
It turned out to be the starter, replaced it and put in another starter solenoid and it works again.
blacklab1
Dec 17, 2018 06:46 PM
mOROTBREATH
18
Sep 24, 2013 07:01 PM
guitarnik
Sep 2, 2008 08:04 AM
78'Ranger
Aug 26, 2007 08:14 PM
ford390gashog
Feb 14, 2004 11:54 PM
