tranny problems and trouble codes
Old Jun 24, 2012 | 05:17 PM
md2of2's Avatar
md2of2
Hello everyone, I'd like to first say I have done alot of research on this site and found it to be an invaluable tool, thanks so much. My current issue is that my od light blinks more often than not but seems to be intermintent, it also has broblems hitting the passing gear. If I accelerate from a stop sign at half throttle everything works fine, pedal to the metal it reaches approx 3500 rpm and seems to lunge and will not shift untill I let off the pedal. I should note that it seems to shift at about 2500 rpm in normal situation, it also does this on freeway doing about 70 and I punch it and nothin it actually slows down, unless I really feather it than I can get her up to 80. Ive also thrown some trouble codes. They are as follows, p0174 and p0171, p1130 and p1150, and also p0443. The 1st 4 I beleive are related to a bad 02 sensor, what do you guys think. The last p0443 I have'nt a clue. My real question I guess is could these issues be affecting the tranny performance. I should also add that it has taken a long time for it to warm up even when it's hot out, in fact if I give it gas before it's warm it almost seems to backfire. I am not sure how to tell what trans I have. Thanks for any info in advance and thanks for taking your time to be a part of this site. I recently rebuilt the whole front en of my truck and could not have done it without you guys.
Old Jun 24, 2012 | 05:39 PM
54FordF1shortstep's Avatar
54FordF1shortstep
What kind of truck do you have. Some have a modulator valve on the side of trans with vacuum line going to it. When they go bad they make autos act all kind of crazy. If it has this part I would replace it first as it is usually inexpensive around the 10 to 20 dollar range.
Old Jun 24, 2012 | 05:43 PM
md2of2's Avatar
md2of2
Oh yeah
I guess I should've mentioned I have a 96 f-250 4x4 with the 460.
Thanks for the advice.
Old Jun 24, 2012 | 05:53 PM
54FordF1shortstep
Well check for that modulator valve Im not sure what year they went to electronic Im thinking 97 so yours probably still has one.
Old Jun 24, 2012 | 05:59 PM
md2of2's Avatar
md2of2
don't have one
From what I can find they were on the c6 trannys, I say that because chilton's only gives inst. on changing the vac modulator on a c6. Chiltons is not my fav though. I'm not sure how to tell what trans I have. Any ideas on my trouble codes.
Thanks
Old Jun 24, 2012 | 06:13 PM
54FordF1shortstep
I would agree that the first codes indicate a bad O2 sensor on bank 2 and 443 is an evap code usually from bad gas cap or recirc system problem which I would not worry about. The O2 sensor can cause it to feel underpowered or hesitate when full throttle so I would replace it. Usually you can identify the trans by counting the pan bolts but you will see that modulator it will be hard to miss its usually mounted close to the pan. Im sure you can find something online that tells you how many bolts the C6 trans pan has. You might try changing the sensor first and see if it helps the other problem too sometimes these can be connected.
Old Jun 24, 2012 | 06:49 PM
md2of2's Avatar
md2of2
I was able to identify, it's a e-40d.
Thanks again.
Old Jun 25, 2012 | 07:55 AM
rla2005's Avatar
rla2005
I have run across several of these OBD-II trucks with the P0443 and blinking O/D light problem over the last year or so on this and a few other forums. So far the ones who have reported back have resolved the issue with a new PCM.
Old Jun 30, 2012 | 10:57 AM
md2of2's Avatar
md2of2
well that didnt help
replaced both o2 sensors and nothing changed. I'm still throwing the 1130 and 1150( lack of heated o2). What is the next compponent, what controls the heat going to the o2.
Thanks
Fordguy84
Dec 1, 2015 06:05 PM
rch10007
Oct 21, 2013 09:11 PM
jackofalltrades1980
Mar 21, 2011 12:08 PM
Soaring
Oct 15, 2005 02:55 PM
Alaska7.3
Aug 15, 2004 01:16 PM
