How you identify engine
Old Jun 23, 2012 | 02:33 PM
Yahiko's Avatar
Yahiko
Question How you identify engine
I have access to a used lot of loose parts
for a 6.0L. The block,heads and turbo are not in the lot.
How do you tell what year they are from?
Sean
Old Jun 23, 2012 | 03:42 PM
BLADE35's Avatar
BLADE35
What parts then
some have been updated so may get little confussing
Old Jun 23, 2012 | 11:36 PM
Yahiko's Avatar
Yahiko
From the photos and I was able to call and talk to the guy that has the lot.
It was not his engine to start with.
What I see is the crank,cam, low pressure oil pump, valve covers, glow plugs,
several bags of small parts. some thing that looks like a windage tray and the lower half
of what looks like the main bearing caps, oil cooler and filter assembles, water pump,
front and rear covers, I can't tell it there is a HPOP, Lifters,intake manifold,
Not sure if there are any injectors. Some other odds and ends.
When I talked to the guy on the phone he said that the valve cover had a 06 date on it. But was not sure if it was all from the same engine. I will go have a look at it Monday.
Do the heads come with an upper bolt on part I see something that looks like
it goes under the valve cover on top of the head?
Sean
Old Jun 23, 2012 | 11:49 PM
BLADE35's Avatar
BLADE35
The heads have 2 diff size Head Alignment Dowels
18MM & 20MM
yes some of the head bolts go under valve cover but bottom head bolts are exposed
Sounds like someone did an overhaul and had a doner engine
Becareful some them parts might be Junk and they probably took all the good stuff
Old Jun 24, 2012 | 12:16 AM
Yahiko's Avatar
Yahiko
That is just what I was worried about. I wished I had the crank journal
sizes It's easy to measure.
Sean
Old Jun 24, 2012 | 12:55 AM
BLADE35's Avatar
BLADE35
well I see you have an 06 too so maybe
If its been in the weather Id probably Pass IDK if its DIRT cheap that might be something
but without knowing all that high tech stuff like you mention might be more trouble than its worth
But there could also be a Diamond in a Pile of DOG Sh!^ Good Luck
Old Jun 24, 2012 | 07:34 AM
cheezit's Avatar
cheezit
the lower half of what looks like the main bearing caps. Thats called a bed plate and its lined bored to mate with the block it came from so its of no use.
The crank and cam I dont think I would buy either.
an extra front and rear cover may be worth having as will as valve covers. But I have only had to replace maybe 3 rear covers.
Front cover is were the lpop goes need to varifiy there is no damage to the inside were the pump gears run.
Dont think I would run a used oil pump or unknowen uned lifters either.
Buying the lot of parts listed is not really worth it imo.
Old Jun 24, 2012 | 08:02 AM
mhatlen's Avatar
mhatlen
2006 Bullet-Riddled 6.0
My brother n/law has 2 f250 trucks with 6.0 in both that broke down and were out of warranty and he parked em both. I have grabbed the ficm,s out of both and the cats and a few other parts.
I am guessing they gotta be worth someting 05-06 they were complete till I got a hold of em. Have thought about pulling one out and keeping before he takes them to the wreckers. Right now they are doners for the rest of his fleet.lol kinda sad
Old Jun 24, 2012 | 12:25 PM
Yahiko's Avatar
Yahiko
mhatlen,
How did they die? I am looking for a motor that can be rebuilt. I should also ask if he would want to sell them.
Sean
Old Jun 25, 2012 | 09:39 PM
Yahiko's Avatar
Yahiko
Well I went today and had a look at the lot.
No HPOP, oil cooler cover,intake manifold.
Here is the post on Ford 6.0 diesel engine parts most brand new, one lot to many to list see pics | eBay
The price I had was lower than what you see here. I did not buy it
because of the items that were not included.
Sean
Old Jun 26, 2012 | 07:20 PM
cheezit's Avatar
cheezit
the parts all look used and nothging of any real value in the lot. good job saving $650
Old Jun 26, 2012 | 07:57 PM
Yahiko's Avatar
Yahiko
I don't know if this is a problem or not but I read somewhere that
you should not remove the bolt on section of the crank under
the dust shield and it was off. Also I did see some sings of
use on the journals not too bad.
But for what was there I felt it was too much even at the lower price he
had asked $500 not the $650 on Ebay.
Sean
Old Jun 27, 2012 | 07:58 AM
mhatlen's Avatar
mhatlen
He said they both had overheating problems. If your looking for the engines or transmissions:yea he will sell them,probably cheap. they both have around 100k on em.
As far as the trucks themselves they have become DONER vehichles for the rest of the fleet,someone smashes up something and it's getting yanked off of the two sitting.
There were 4 of them aquired through a purchace of a company 2 are still on the road last I heard. Maintanance is not his strong point, once they were out of warranty and they broke down he parked em!! If your interested let me know I can make a call, have to admit I have pulled a few parts off em myself ficm's glow plug controller egr valves cats otherwise thier complete. lol
Oh yea one is 05 other is 06 both f250 4X2 pressure wash company never pulled trailers hauled pump/steam cleaners
If I had to guess I bet they both have blown egr coolers maybe a head gasket issue but doubt it. Blocks are complete w/turbos
Justus6.0L
Feb 24, 2017 02:00 PM
mechanic58
Nov 6, 2014 03:18 PM
famuel
Mar 18, 2001 04:29 PM
cduvall1
Aug 3, 1999 07:06 AM
