code PO122, 6.0 2003 erratic at idle
Old Jun 21, 2012 | 09:41 PM
learning diesel's Avatar
learning diesel
Question code PO122, 6.0 2003 erratic at idle
Please help. I've got a F350 2003 6.0 (mfg. date Apr. '03) that when started for the first 15-30 minutes may idle at 750-800 rpm and suddenly jump to 1150-1200 rpm, may idle back down erratically and occasionally will suddenly die but will start right back. It will run good on the highway after it is totally warmed up. It seems to have good power and is not sluggish. I've checked it with OBDII and it shows only one code: PO122 and it described a problem with Throttle Position Sensor. Is it the Accelerator Pedal Position Sensor or another sensor somewhere? Does this vehicle even have a throttle position sensor? How do I check this out? Anyone have a suggested troubleshooting process ?
tomsykes004
Jun 18, 2019 07:54 PM
Jmoen7
Aug 25, 2015 09:47 PM
kstones63
13
Jun 5, 2014 08:04 PM
af11
Apr 20, 2014 10:38 PM
mountaineer03psd
Jun 30, 2007 08:57 AM
