Rolling Idle
Old Jun 28, 2007 | 12:49 AM
mountaineer03psd's Avatar
mountaineer03psd
Angry Rolling Idle
I have a 2003 6.0 with 125,000 miles. Noticed it started surging while driving and while in park or stopped at a stoplight the rpm's would rise from 500 to 1000. It would also drop below 500 and almost die, it does this whether the egr is unplugged or plugged in. I read that the ebp sensor is prone to failing and replaced it, but it's still surging. Anyone have any ideas?
Old Jun 28, 2007 | 01:13 AM
grinekb's Avatar
grinekb
I have the same thing happening with my 03 with 133000 miles on it and i had a mechanic tell me to change the exhuast pressure sensor.
Old Jun 28, 2007 | 07:02 AM
BowTieHatr's Avatar
BowTieHatr
probably the icp sensor.
Old Jun 28, 2007 | 07:40 PM
msgtg's Avatar
msgtg
Hey 'eer', did it start all at once or has it been gradual?
Joe
Old Jun 28, 2007 | 10:51 PM
mountaineer03psd
It just happened one evening on my way home. BTW it won't do it with the engine cold, does it with the engine hot and it happens randomly.
Old Jun 29, 2007 | 12:02 AM
rollerstud98's Avatar
rollerstud98
i was having the same problem, mine was a harness that they had to rebuild, i'm not sure which one but this was almost a year ago and i haven't had any problems since
Old Jun 29, 2007 | 03:13 AM
jblksmith1's Avatar
jblksmith1
I am having the same exact problem. Of course my dealer will claim I am driving it like a girl or some other ridiculous thing. It goes into the shop on Tuesday. It is an 04 with 64,000 miles. Any suggestions on what I should tell them?
Old Jun 29, 2007 | 06:03 AM
msgtg's Avatar
msgtg
Geez, from what I've read there are several sensors that could cause the condition. I was kinda hoping mrxlh or blackhat would jump in here and give us some ideas.
Joe
Old Jun 29, 2007 | 06:56 AM
BowTieHatr's Avatar
BowTieHatr
well if you want to know their opinion then send then a pm.
Old Jun 29, 2007 | 12:03 PM
blackhat620's Avatar
blackhat620
As "BowTieHtar" said probably the ICP sensor.
I am with BowTieHatr on this one, and you guys realize the BowTieHatr is a Ford 6.0 Tech and has seen more of these failures than either myself or mrxlh combined. I would stongly recommend you heed his advice. But remember without the truck in hand and diagnostics performed, an absolute diagnosis given over a computer on the internet is difficult.
Take your truck in and let the 6.0 tech do there job and get your truck running properly
Old Jun 29, 2007 | 04:23 PM
msgtg's Avatar
msgtg
Ahh....I've learned something new AGAIN. Thanks blackhat...I didn't know he was a tech!
Thanks for all the info BowTieHtar!
Joe
Old Jun 29, 2007 | 09:41 PM
blackhat620
Joe
There acutally is a list of 6.0 diesel techs that are FTE members, thanks to kw5413, it was compiled about 9 months ago and is now part of the 6.0 Tech folder.
http://www.ford-trucks.com/forums/52...ml#post3998872
Old Jun 30, 2007 | 02:07 AM
mountaineer03psd
Is there a way to check the icp with a voltmeter? If not i can take it to the dealer.
Old Jun 30, 2007 | 07:22 AM
BowTieHatr's Avatar
BowTieHatr
there is so little room under the turbo, there is just enough for tools for replacement. i hate to tell you but scan tools are the only way to tell. now you just have to find a place with a knowledgeable tech behind it.
Old Jun 30, 2007 | 08:57 AM
mountaineer03psd
thanks for the info bowtiehatr, looks like i'll put it in the shop monday
