Throttle position sensor
Old Jun 18, 2019 | 04:55 PM
tomsykes004's Avatar
tomsykes004
I ran diagnostic on my truck and got the code for a throttle position sensor, the truck was running very weak when put into gear like backing in and out of parking spaces the engine would stall out multiple times. I replaced the tps and now I I am idling at a very high rpm and when I try to put t it in gear everything bucks, any ideas as to adjustment I can make?
Old Jun 18, 2019 | 06:22 PM
torq'ta 5 8's Avatar
torq'ta 5 8
more truck info, year, model, motor, trans, what was idle before you replaced tps, what is idle now? what was actual code?
Old Jun 18, 2019 | 06:30 PM
tomsykes004
5.8, automatic, 4x4
The idle was weak before changing, I unplugged the new tps and the idle came down remarkably. Code was 0122 tps
Old Jun 18, 2019 | 06:43 PM
torq'ta 5 8
read this to assure you set tps right
Throttle Position Sensor Testing, Replacement and Adjustment - Ford Bronco Forum
Old Jun 18, 2019 | 06:57 PM
puppyf250's Avatar
puppyf250
Originally Posted by torq'ta 5 8
This is correct, it is very very easy to set these up wrong.
Old Jun 18, 2019 | 07:54 PM
timbersteel's Avatar
timbersteel
Did you disconnect the battery? When changing sensors, known bad sensors, you should do this so that the PCM can learn new idle/driving strategy.
If you didn't, then the PCM is still using old values learned from erroneous sensor data.
Diesel_Brad
1983 - 2012 Ranger & B-Series
Jul 22, 2018 02:56 PM
ResJudicata
Jan 7, 2016 09:52 AM
kstones63
13
Jun 5, 2014 08:04 PM
TexasTornado66
Aug 16, 2010 03:51 PM
gijoe985
1997 - 2003 F150
Jul 15, 2008 11:03 AM
