Sponsored by: Real Truck
Transmission Service
Old Jun 21, 2012 | 12:42 PM
GeneLaw1's Avatar
GeneLaw1
Good people,
'06 F250 Stroker here. I was going to try to get my transmission serviced within the next week. Would you all recommend the dealer or is it something that I can go to somewhere like AAMCO for? If I go to the dealer is there is anything special I am to ask for? Like do I Want a "drain and fill" or is the word "transmission service" pretty much have the same meaning across the board?
Thanks!
Old Jun 21, 2012 | 02:22 PM
maverick22's Avatar
maverick22
I'm assuming this is an auto? The TorqShift tranny requires a heated flush machine to get all the fluid so it's most likely a dealer only service. 2006, I think, should still have the external TP filter up by the front bumper, make sure they change that as well. "Tranny service" should include all of that. Might double check them on the external filter though, newer ones don't have that.
Old Jun 21, 2012 | 02:52 PM
kd0axs's Avatar
kd0axs
Another thing, make sure they use ONLY Mercon LV fluid. There was a member a few days ago that had a dealer (yes, a Ford dealer) put some other junk in when he had a flush done.
Old Jun 21, 2012 | 02:58 PM
Gage2502's Avatar
Gage2502
I though that the TorqShift Tranny takes the Mercon SP fluid?
~Gage~
Old Jun 21, 2012 | 03:26 PM
kd0axs's Avatar
kd0axs
They don't make Mercon SP anymore, it was replaced by Mercon LV.
Old Jun 21, 2012 | 03:42 PM
Gage2502's Avatar
Gage2502
O I didnt know that....Thanks for that.
~Gage~
Old Jun 21, 2012 | 05:41 PM
GeneLaw1's Avatar
GeneLaw1
Thank you for the information, and yes it is an auto tranny!
Old Jun 21, 2012 | 09:36 PM
redford's Avatar
redford
FTE Leadership Emeritus
A Torqshift takes special equipment to flush. A chain or neighborhood shop usually will not have this equipment. The fluid must be heated to open up the thermostat in the transmission so all of the fluid can be flushed. If a shop says they can do this, the next question is what fluid will they use? If they say anything besides Mercon LV (or maybe SP) ask them to PROVE that the fluid is compatible. Do not take their word, as incompatible fluid will cause your transmission to fail.
Old Jun 21, 2012 | 11:13 PM
GeneLaw1's Avatar
GeneLaw1
I am just going to take it to the dealer and call it a day.
Old Jun 21, 2012 | 11:23 PM
kd0axs's Avatar
kd0axs
Good idea, but still make sure they are using Mercon LV. See this thread, this guy went to a Ford dealer and they put the wrong fluid in, but insisted it was fine and refused to replace it with Mercon LV.
https://www.ford-trucks.com/forums/1...mercon-sp.html
Old Jun 22, 2012 | 01:40 AM
onug's Avatar
onug
Had mine done yesterday. $300 out the door, including filter.
Old Jun 24, 2012 | 01:19 PM
GeneLaw1's Avatar
GeneLaw1
Sheesh, not a cheap procedure I see, lol
Old Jun 24, 2012 | 01:21 PM
GeneLaw1's Avatar
GeneLaw1
I will make sure of this before I sign the papers.
Old Jun 24, 2012 | 02:55 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
Not all dealers have a heated flush machine either. Make sure to ask if they have the proper heated flush machine along with the proper fluid.
Your best bet is to find a dealer that has a truck shop that is separate from the regular maintenance area as these tend to know the service requirements that are unique to the Super Duty.
H2oSprayer
Jun 7, 2009 02:59 PM
spr1516
Mar 13, 2009 03:27 PM
michaeloac
Sep 23, 2008 03:41 PM
Joshua0606
Nov 20, 2007 06:55 PM
Kaloha
Jun 21, 2004 11:11 AM
