i have a 06 f250 with 26K on it an i will be gettin a tranny flush soon do i have to go to the dealer for the 30K service or can i go anywhere i do my own oil changes/dif changes ect.. just need the tranny flush can i just go anywhere to get a tranny flush or do i have to have it done at the dealer???
technically any reputable shop can do a flush. make sure they use the proper fluid. The newer Fords require Mercon V. Dexron/Mercon type fluids are not up to spec.
I prefer dropping the pan and changing the filter and checking for loose bolts. A lot can be diagnosed by what you see in the pan. But with your low miles a flush is plenty good.
I am pretty sure by law, As long as you perform maintenance at prescribed miles and using fluids up to specification, you are covered under warranty. Keep receipts.
i can't see why you couldn't get it done at a local shop. the dealer would probably charge you more anyway. and if you take it to your local shop, make sure they drain the converter too
yeah at the dealer they are trying to charge me about $300 screw that i can go to the local shop an get it done about $150 i just didnt no if the local shop would **** it up since i no the torshaft trany use a special fluid or so i hear
The original post was about an '06 F250. All of those have a TorqShift transmission. MERCON V will KILL the solenoids in a TorqShift. It must use MERCON SP, not MERCON V. And it requires a heated flush machine, too, or the internal thermostat will be closed and it will just mix old and new fluids instead of flushing.
I would suggest getting the 30K svc at the dealer, not just because of the tranny but there are other items to be taken care of. I think mine cost around 400.00 when I had it done on my 06.
Included front 4x4 maint, trans, eng oil, driveline.
