Steering box adjustment, have we been doing it wrong?
Old 06-18-2012, 10:41 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
So I just brought back a 96 F250 for my parents business. Truck has 64,000 on the clock and had a little bit of steering wheel slop. I went in to do the steering box adjustment and found something of interest.
I marked the box/nut/stud with a white paint marker so I know factory settings. I loosened the nut and turned the stud 1/4 turn out. Felt the steering wheel and seemed no change. Did another 1/4 turn out and felt again, no change. Did another 1/4 turn out and no change in the slop and the steering started to get a little funny. So then I went back to factory setting and went 1/4 turn CLOCKWISE with the stud. Steering started to tighten up instantly! Another 1/8 turn CLOCKWISE and all the slop was gone! AAAAAANNNND the steering is as light as a feather! The truck steers much like my 92 crown vic did now. I left it there to see how it goes and all seems good so far.
So it bring up a question. I wonder if the box can be adjust either way to take the slop out (factory adjustment)? I also wonder if the "adjustment done at the factory" depends on who is working that day and which way they adjust the box? Is it ok to adjust the slop out of the sector shaft by adjusting the stud clockwise?
The reason this seems so "correct" to me is because there have been a couple boxes now that seem to have no change or get worse when adjusted counterclockwise. I never tried to adjust clockwise before this one and I am questioning now if some boxes would have been better adjusted "in" instead of "out"?
What is your guys take?
I am very tempted to readjust my X box clockwise now to see what the effects are.
Old 06-19-2012, 09:59 AM
Snowseeker's Avatar
Snowseeker
Nothing yet? Everyone must be out driving their X's eh?
Old 06-19-2012, 10:11 AM
Snowseeker's Avatar
Snowseeker
This is a good read and confirms the sector shaft adjustment stud should be turned CLOCKWISE to take the "some" slop out of the steering.
http://www.stangerssite.com/adjustment.html
All these years I've been doing a quick search on here and kept seeing people say adjust the stud CCW. I always wondered if that was totally correct and questioned it when I would see no change in the steering slop when adjusting some boxes.
I'll have to go back and readjust all of our trucks boxes now.
Old 06-19-2012, 10:14 AM
indyF-350psd's Avatar
indyF-350psd
indyF-350psd is offline
you can't fix stupid!
thats weird people would say ccw....ive always seen it you tighten the stud down to make it tighter and loosen it out to loosen it.....didnt you get a redhead? or did it go on a different truck?
Old 06-19-2012, 10:26 AM
Snowseeker's Avatar
Snowseeker
Maybe I was just getting the wrong threads when I searched. It was always a "run in, jump on the net and check" thing. So I never took allot of time to search multiple resources if the CCW adjustment was right or not.
I will have to write it down in the shop.
No I did not get a redhead, my X box wasn't quite loose enough yet to justify the price. I am going to recheck its adjustment today, it may be totally fine yet.
Old 06-19-2012, 11:21 AM
bigwhitetruck01's Avatar
bigwhitetruck01
bigwhitetruck01 is offline
When I did mine (V8, 4x4, 124k), I loosened the lock nut, turned the stud clockwise in 1/4 turn increments until I was satisfied with the adjustment, then locked the nut back down.
Old 06-19-2012, 05:20 PM
locknload223's Avatar
locknload223
locknload223 is offline
Righty Tighty here too. Loosen the nut the tighten the stud. I did it that way on all my old Toyota trucks and Excursion.
Old 06-19-2012, 05:24 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
Same here, clockwise about a full turn. It's been fine ever since.
Old 06-19-2012, 06:24 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy
X_Hemi_Guy is offline
Clockwise for me too...
Here's the original thread
https://www.ford-trucks.com/forums/5...-steering.html
I posted a link (post #2) to that thread in Stewart's comprehensive steering thread...
https://www.ford-trucks.com/forums/7...mpilation.html
Old 06-19-2012, 07:19 PM
Snowseeker's Avatar
Snowseeker
Well, I shouldn't ever forget now.
Old 06-19-2012, 08:48 PM
Curt's05's Avatar
Curt's05
Curt's05 is online now
Wiser by FTE
I adjusted mine by using black tape on the steering wheel at 9 o'clock with pressure on the steering wheel clockwise & more black tape at the same position with pressure on the steering wheel counterclock wise. This way i could see i had about 3 inches of play/slop in the steering wheel. After loosing the jam nut & turning the screw in about 1 turn, the slop/play was visibly down to an inch! Since then the slop is creeping back to about 2 inches now.
Old 06-19-2012, 09:59 PM
EXv10's Avatar
EXv10
EXv10 is offline
Clockwise I tell ya! Clockwise!
Old 06-19-2012, 10:24 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
No we haven't, just you brother.
That you should tighten by turning clockwise!
You should. It'll tighten your steering right up! Especially since you turned it the wrong way the first time!
Stewart
Old 06-19-2012, 10:29 PM
Stewart_H's Avatar
Stewart_H
Old 06-20-2012, 07:53 AM
Jmatthews's Avatar
Jmatthews
Jmatthews is offline
is a BAAAD MAN
Righty tighty.
Quick Reply: Steering box adjustment, have we been doing it wrong?
