Shifter blues
Old Jun 17, 2012 | 09:18 AM
MSCritter's Avatar
MSCritter
Shifter blues
Hi everyone, does anyone know if you can move a tranfer case shifter into another place- say to the right or some other place. I would like to put in a hurst quarter stick if i can. Also while im at it i would like to put a e- brake [pull style] there if i can. I have a bench seat that i need to keep so i can take my granddaughter {7 years old right now} with us as well. Alot to ask for sure but im hoping it can be done with some help from peoples with more smarts in this area than i have . Can the t-case shift be modified to be cable operated? 80- f150/ 351m/ c6/ t-case? Hurst is cable operated.
Old Jun 17, 2012 | 09:37 AM
82f100460's Avatar
82f100460
Found this out there where someone was doing it on his Suburban. I'm assuming you probably have an NP208 so that's what I searched on.
NP208 TC shifter relocation - Pirate4x4.Com
Old Jun 17, 2012 | 11:10 AM
Diesel_Brad's Avatar
Diesel_Brad
Pretty sure that will Not work being the t-case on a chevy is passenger side driven
Old Jun 17, 2012 | 11:29 AM
MSCritter's Avatar
MSCritter
Ill check it out know anyways this is a good start Thanks guys
Old Jun 17, 2012 | 11:37 AM
82f100460's Avatar
82f100460
yeah I'm not sure either...haven't modified any 4x4 stuff before to be honest. But in that thread, he was stating you can hook up a B&M cable and put the shifter anywhere you want. So it sounded pretty universal of a solution, regardless of what side the TC was mounted on.
graymule
Jul 12, 2010 05:21 AM
dantsg
Mar 26, 2008 08:09 PM
imlowr2
Jan 1, 2006 09:04 PM
tastyklair
Aug 17, 2004 12:42 AM
remmers
Nov 2, 2003 08:27 AM
