Shifter
Old Mar 24, 2008 | 10:37 PM
dantsg's Avatar
dantsg
Shifter
Has anyone tried the Hurst or BM shifter with a c6 in a F150?
I have to replace the shift cable and it is just about as cheap to go with a floor shifter.
Dan
Old Mar 24, 2008 | 10:47 PM
fastfarmer's Avatar
fastfarmer
If you check out the "heater core and dash disassembly" thread below you'll see a nice photo of what looks like a B+M shifter installed. Looks good in there.
Old Mar 24, 2008 | 10:49 PM
fdude64's Avatar
fdude64
shift cable what year truck you got? my c6 has a linkage i believe
psquare7575's Avatar
psquare7575
It's actually a Hurst, but yah, I like it. It changed the truck feel from 'farm truck' to 'urban street machine'.
Ok that's pushing it.. it's still an old farmers wife's truck with a floor shifter. I like it.
Old Mar 24, 2008 | 11:53 PM
offroadracer99's Avatar
offroadracer99
I got a B&M Truck Shifter in my F-250, I like it. It wasn't too bad to install and didn't have any problems with it.
Old Mar 25, 2008 | 01:24 AM
JRuel's Avatar
JRuel
NIIIICE interior offroadracer! Got anymore pics?
A friend of mine has a B&M in his 78 2wd. Seems to work great.
Old Mar 25, 2008 | 01:43 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by dantsg
I have to replace the shift cable ?? and it is just about as cheap to go with a floor shifter. Dan
No 1973/79 F100/350 has any sort of a shift cable.
Look at the bottom of the steering column underneath the hood for the trans control selector lever where the shift rod attaches. Inside that selector lever is a snap in bushing. There's another like bushing in the manual control lever on the trans, where the shift rod attaches. Either one or both of those bushings is either missing, cracked or worn. That'll cause slop in the the shift lever and it may not engage the transmission.
Ask Mil1ion to post these two parts catalog illustrations...both show how the SHIFT ROD attaches...Look for the Ford basic part number of 7341 = the bushings.
Section A70.2 / Page 9 upper pic, shows the trans manual control lever, other parts.
Section A71 / Page 7 lower pic, shows how the shift rod attaches to the control selector lever, on the bottom of the steering column.
Both bushings are the same, and are available from Ford, NAPA, etc.
The "snap in" bushing is either black or green plastic and it has a shoulder on it.
Old Mar 25, 2008 | 04:17 PM
jsutton's Avatar
jsutton
Here's my B&M Zgate shifter I just put in my truck. It'll look better after I get my new carpet. My truck has a C4 but the instructions are the same for the C6 you just use a different cable bracket.
Old Mar 26, 2008 | 08:09 PM
offroadracer99
Look at this thread, right at the top of page 20. This should be a direct link. Enjoy!
https://www.ford-trucks.com/forums/7...ur-4x4-20.html
TJ62
Nov 29, 2014 11:23 PM
laptopgeek
Aug 30, 2002 09:59 PM
Mike W
Jun 7, 2002 07:44 PM
Superdave
Nov 2, 1999 06:37 AM
