Dual alt's for electric fan setup
Ive been thinking about putting an electric fan to give me a little boost on power by dropping the motor driven one. The main issue i got is I can't really afford a bigger amp, then it hit me.....maybe I can run dual alternators because I have a gap above the alternator on my orange explorer unlike the blue ford that I'm now using as parts and will eventually part the rest of it put if anybody is interested on any of the pieces I don't use. Is there a way to mount the other alt I have? I know I'll need a bigger belt, just need some help on how I could mount the other one if it is feasable.
It doesn't make sense to use two sub-standard alternators to avoid the cost of doing things the right way. This would also leave a mess of wiring. Instead, you should do a 3G swap with a junkyard alternator. One of the many threads on this topic should have a cost worksheet; it's not all that expensive.
I run a dual V-groove alt pulley on my 3G and use two belts to hedge against the possibility of breaking one.... plus a dual battery system is in my future. It's been done cheaper but my 3G retrofit only cost about $50 and I'm getting 14.62 VDC at idle.
Josh
Electric Fan Conversion Using the Notorious Lincoln Mark VIII Fan - FordMuscle
73 fourxfour
06-16-2012 07:42 PM
