carb problem
Old May 6, 2003 | 10:22 PM
kevinken's Avatar
kevinken
Question carb problem
I have a 1983 Ford Bronco with a 300 6 in it. For the past week I have been having problems with the carb (Carter YFA 1 bbl.) When I start it up everything is fine for about 2 minutes. Then gas starts leaking heavily out of the middle area of the carb over the manifold. I turn off the engine and it continues to slowly drip out of the front and back areas of the carb. I cannot pinpoint where the leak is coming from or what is causing the leak. I have installed new gaskets and fuel filter and I have tightened up every bolt and screw but it continues to leak. Does anyone have any ideas of what might be causing this? I have checked the float and it is fine. Thanks.
Old May 7, 2003 | 09:12 PM
broncr's Avatar
broncr
carb problem
'Sounds like a problem with the "feedback" carb which came out in '83. I've read a few posts about problems associated with it. Sorry, I can't be of much help other that to recommend a search here for "feedback carbs", "carter", "1bbl"....
pushinoleblue
20
Nov 10, 2009 10:22 PM
Rusty_Old_F250
Nov 1, 2009 12:07 AM
kevinken
1978 - 1996 Big Bronco
May 6, 2003 11:00 PM
kevinken
May 3, 2003 09:04 PM
cat house mouse
Mar 11, 2002 06:33 PM
