leaky carb?
Old May 3, 2003 | 04:40 PM
kevinken's Avatar
kevinken
Question leaky carb?
I have a 1983 Ford Bronco with a 300 6 in it. For the past week I have been having problems with the carb (Carter YFA 1 bbl.) When I start it up everything is fine for about 2 minutes. Then gas starts leaking heavily out of the middle area of the carb over the manifold. I turn off the engine and it continues to slowly drip out of the front and back areas of the carb. I cannot pinpoint where the leak is coming from or what is causing the leak. I have installed new gaskets and fuel filter and I have tightened up every bolt and screw but it continues to leak. Does anyone have any ideas of what might be causing this? Thanks.
Old May 3, 2003 | 09:04 PM
lee's Avatar
lee
leaky carb?
KevinKen,
My best guess would be that the float in the bowl is stuck or the bowl's fuel inlet valve is sticking open.
Hope this helps,
aricanderson
Nov 4, 2009 04:35 PM
Rusty_Old_F250
Nov 1, 2009 12:07 AM
TX-Breeze
Feb 10, 2004 07:13 AM
kevinken
May 7, 2003 09:12 PM
kevinken
1978 - 1996 Big Bronco
May 6, 2003 11:00 PM
