Carburator bubbling gas?
Old Oct 31, 2009 | 12:45 PM
Rusty_Old_F250's Avatar
Rusty_Old_F250
Howdy all, I'm having some carburetor bubbling gas problems, it happens whenever I start my truck, and after a few revolutions of the motor gas starts to bubble out of the top of the carb. I have just done a carb kit on it (my first carb kit, by the way) and I've had the carb on and off since I discovered this problem at least a dozen times. I'm guessing its the needle valve, but I've messed with it to no end, and finally replaced it last night, but the problem continues. Here's a picture, I circled the areas where the gas bubbles out in red. The carb is a Motorcraft 2100-D and its on a 390 in my 173 f250, but, the motor isn't original to the truck, and the carb probably isn't either.
Has anyone else had this problem? Also, I need a fix soon, the county has decided to gate off the alley where the truck is parked, they have the gates up, they just haven't closed them yet, so I need to be able to get this thing out of there.
Sam
P.S. Just in case anyone needs to know, the original reason I did a carb kit was because it was leaking from the gaskets in the throttle linkage and on bottom of the carb.
Old Oct 31, 2009 | 12:50 PM
fmc400's Avatar
fmc400
MSEE
You guessed it, the needle can't seat. Make sure that the float is clipped into place, and double-check the float height measurement.
Old Oct 31, 2009 | 01:27 PM
Rusty_Old_F250
Boy, do I feel dumb, I just took a real close look at that parts diagram, and I've lost a spring. No new one in the carb kit either, or if there was, I must've lost it too. The spring is the one that is mounted on the float's pivot and makes the needle valve seat. Well, how exactly do I go about finding a new one? Buy a junkyard carb and take it off of that?
Thanks,
Sam
Old Oct 31, 2009 | 06:59 PM
cougarshaman's Avatar
cougarshaman
That is correct. Grab one at a junkyard, or just go ahead and buy yourself a spare carb for parts or as a backup.
Old Oct 31, 2009 | 08:39 PM
fmc400's Avatar
fmc400
MSEE
That spring is to keep the carburetor from flooding out on inclines. It's for off-road use; you don't need it for normal operation. You can get by without it, and it's not the source of your flooding problem.
Old Oct 31, 2009 | 11:13 PM
79FordBlake's Avatar
79FordBlake
Maybe the clip on the float isnt hooked to the needle?
Old Nov 1, 2009 | 12:07 AM
Rusty_Old_F250
Well, thanks for your suggestions, but for a temporary fix I made my own spring out of a paper clip. I figure the springs purpose is to keep the float, pivot and the needle valve from rising too much, and my paper clip does the job. At first I wasn't too sure about it, but it worked, and no more gas is bubbling out of the carb! I even went for a short drive around the block, everything worked great. However, I do plan on getting a junker carb and pulling a spring off of it the first chance I get.
Sam
Thed
204
Aug 30, 2016 11:44 AM
rlacan71
13
Aug 19, 2015 03:07 PM
KIKKUP
Feb 25, 2013 11:49 AM
Longland
Oct 16, 2011 05:33 PM
Aaron-71
24
Jun 28, 2011 10:52 PM
