Hi everyone! I'm restoring a 1951 F1, on a 1952 frame for my boss. This is my first Ford restoration and so far it's been cool. He wants it stock, an homage to his grandfather, and I need help in sourcing parts. I have one rear spring hangar pin that won't come out. pounded it in a bit to free it up and threaded a 4" nipple into the grease fitting hole and used a slide hammer. Didn't budge. Anyone have a tip for removing it?
I probably won't help much but wanted to say welcome to FTE
I'm probably thinking of the wrong part, but have you tried heat yet? If it's something you can take a torch too the heat will shrink it a tiny bit and then it's easier to remove. Sometimes you just need a little heat (300 degrees), sometimes it needs to glow (1450 degrees).
Is all the weight (or spring force) off the pin? Even the weight of the spring needs to be off it. The part of the pins inside the spring get worn on the OD, so you need to be able to get the larger, unworn diameter aligned with the spring ID to get it out. Once that unworn part gets into the spring it usually comes easier. Know what I mean?
Here's an old thread on the subject. You're on the right track using the slide hammer, but I prefer to use the threaded bolt that allows you to really put the torque to the bandit. Stu
I couldn't find a NPT bolt and nut so I threaded in a bolt. I've taken the weight off, wiggled ,jiggled, used every cuss word real and made up. Don't want to start a grease fire in warehouse, fire sprinklers and alarms and all that, so heating the castiron is out. Thanks for the tips!
I was in Qeensland 2 years ago. Loved Austrailia. I got a Falcon XR6 as a rental and had lot's of pix taken, photo radar.. Drove 4000Kms in 3 weeks! If I'd gone as a young man I'd have stayed.
Glad you liked it, a lot of people visit and never go home. I have an F6, the turbocharged, intercooled and tuned version of the XR6, now that's lots of fun.
IF you're talking about the front pin for the rear spring, it's blocked by the crossmember between the frame rails. Take a 3/4" hole saw and cut an access hole in that crossmember level with the access hole in the frame rail for the pin (Ford put a hole in the frame, but apparently forgot about the crossmember). Then stick a big long cheap punch or a long ratchet extension into the hole and knock the hell out of it. It will come. Cutting that access hole takes about 2 or 3 seconds per side. That crossmember is very thin.
welcome to fte. This is a great site. I am a canadian too. Alberta. Anyway I had the same problem with my build last year i had no torch just basic tools a good buzz box type stick welder and a grinder was how i had done buisness on my build. I would love torch set but could never afford this option. So i had taken off the shackle holders off the frame grind down rivets and punch out.Those rivets can be replaced with grade 8 bolts and nylock nuts.Than when you have the springs out you can rest in vise and hit it out. If this dont work and you have no torch mabie propane and penitration fluid might work. If this procedure will not work try stick weld and when it is red pound out.
hope this helps.
oh yeah I forgot supplier George Moir antique ford is a great supplier in the north region for 48-56 fords reasonably priced most things and he has evrything most stock he ships greyhound so you usually only wait 1 day max 2 days otherwise try american suppliers but as us canadians get stung for customs fees and shipping.
George Moir Antique Auto Parts Ltd.
1 Boulder Boulevard
Stony Plain, AB T7Z 1V6
Tel: (780) 963-7334
Fax: (780) 963-6187
Email: info@georgemoir.ca
