Spring Pins F1
Spring Pins F1
Yes I said it the spring pins that hold the rear springs in. How do you remove them?
I have the rear ones out and the front pins up by the cross member wont budge.
I have the bolts/locking pins out.
I even rigged up a fitting with a slide hammer and cant get them out.
These arent in my truck but some scrap I saved from a junker to salvage a few springs.
As they say down in here in New Mexico..."heat it with a torch then heat it with a hammer"
On my 49 I used a chunk of 1/2" round bar as a punch and drove them out from the back side. For the rear shackles there is a hole in the frame for the punch. The front shackles are located behind a crossmember in the frame. Sometimes there is a hole in the crossmember and the frame sometimes there isn't, in my case there was a hole in the frame but no the x-member however, the previous owner had smoked a hole in the crosmember and I was able to use my punch to drive them out.
Good luck
Bobby
Good luck
Bobby
tomrflorida
10-03-2012 12:17 PM
l_buck
06-30-2011 03:14 PM
HSteacher
03-04-2011 05:15 PM
oscarxyz
20
11-21-2005 01:07 PM
