HPX leak
Old Jun 11, 2012 | 07:24 PM
remhaust's Avatar
remhaust
Angry HPX leak
I tried searching for related problems, but didn't find much. Did anyone else have this happen. I was very careful on not to over tighten anything. but after 11/2 years my line started leaking very bad very fast, so i snugged up a bit. Didn't help so I took it off to look at, and it is cracked right above the flare.
Old Jun 11, 2012 | 07:37 PM
Crewcab Turbo's Avatar
Crewcab Turbo
I read a lot on here and I have not seen any posts about problems, so its probably not too common. I would call Clay and see what he can do for you. I would be surprised if he doesn't warranty it.
Old Jun 11, 2012 | 07:59 PM
SARDiverDan's Avatar
SARDiverDan
There is a guy up here that runs a diesel shop and he took his HPx off because it kept leaking. Mine has only been on for about 3 months so I am no help. I have heard of them leaking if you over tighten them or if you put some kind of thread sealant on them. I ordered mine from Clay and I would imagine he could give you a better idea on the number of these that fail with the most common reasons for doing so.
Old Jun 11, 2012 | 08:20 PM
remhaust's Avatar
remhaust
Not a problem, just need to go to work tommorow out of state again. I wounder if anyone knows what site the threads are on the nut so i can maybe just put a internal flare nut/cap on to plug off for now,so i dont have to remove the hpx plugs?
Old Jun 11, 2012 | 08:28 PM
bcaughhorn's Avatar
bcaughhorn
pretty sure mine is a 3/8male JIC
Old Jun 11, 2012 | 08:31 PM
woodnthings's Avatar
woodnthings
Having a cracked flare on a tube is not uncommon. Many times the angle or torque can cause the metal to prematurely fatigue and crack.
You should be able to take the line in with you and get caps for the fittings in the head. It is most likely a #6 size, but hard to say what you actually have. My KCM HPx is #5 which is fairly uncommon.
Old Jun 11, 2012 | 08:54 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Eric, sorry to hear you are having an issue, we really haven't seen much of that. Should be a -6 thread, but would have to look at it tomorrow at the shop. Let me know if you have anything else I can help you with, and also send the line back in if you would like so we can look at it. I would like to see if we can swap you for another one.
Old Jun 12, 2012 | 09:06 AM
CSIPSD's Avatar
CSIPSD
This is why IMHO it is a worthless mod. Does nothing, but its a dandy way to change your oil rather quickly.
Old Jun 12, 2012 | 09:24 AM
empiretc's Avatar
empiretc
Hey now, it's a reason to drink beer and work on the truck, lol...
definitely not common to hear of them leaking. 7.5 years and counting here.
Old Jun 12, 2012 | 09:30 AM
snakedoc's Avatar
snakedoc
i have not read of one leaking. and have had one for 2 years and it dose help my truck idle better.
Old Jun 12, 2012 | 09:38 AM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
i agree with helping the truck idle and run a little smoother.....but they do leak from time to time....just replace the oring and go....although it sounds like this is leaking from a different spot than usual.....
Old Jun 12, 2012 | 10:26 AM
CSIPSD's Avatar
CSIPSD
I've removed 3 myself... Most were the rubber line one's however.
They always leak, there has never been any proven results that they improve anything.
There just one more thing to remove when pulling a turbo...
honeydew
Oct 13, 2012 12:48 PM
stuffdeer
Jan 14, 2011 11:59 AM
daner01
Sep 28, 2010 07:30 PM
InTheDogHouse
May 18, 2010 08:57 PM
Mopey
May 12, 2006 12:59 PM
