Front leaf spring hangers
Old Jun 11, 2012 | 06:17 PM
bigf350sd's Avatar
bigf350sd
Hi. Does anyone know where I can get the front leaf spring hangers for my 47 pickup 1/2 ton? I've found the spring bushings, bolts, shackles, etc...at Mac's, but my hangers appear to be wallowed out, holes ovaled, and I can't find them anywhere. I'm about to think I'm going to have to resort to making some. They appear to attach to the rails with the large steel rivets, instead of bolts, so I guess I'd have to get a grinder up in there to cut the heads down enough to hammer them through. Shouldn't be a problem, though, since it won't matter if I grind into the old hangers a little.
Old Jun 11, 2012 | 09:41 PM
christurney77's Avatar
christurney77
There are some on ebay you can purchase. (that is where I got mine)
1942 44 46 47 Ford Comm Truck NOS LH Front Spring Bracket | eBay
Old Jun 11, 2012 | 09:45 PM
christurney77
I got lucky and purchased both my front set and and back set for $10.00 each (total of $40+S&H)
Old Jun 12, 2012 | 10:10 AM
christurney77
here are some pics
Old Jun 12, 2012 | 04:06 PM
bigf350sd's Avatar
bigf350sd
Thanks a lot christurney77. That link was for the LH, but I don't see how it's offset or anything, so that it wouldn't work on the right side as well. I asked the seller, waiting on his reply. Thanks again.
Old Jun 14, 2012 | 09:22 PM
schoo's Avatar
schoo
i'm in the same boat with my 64' f250 i'm having Rare Parts in stockton making them big $$$ for two shackles
roy
yea know have you tryed a spring repair outfit? they know a lot of supplyers
Old Jun 15, 2012 | 02:04 AM
bigf350sd's Avatar
bigf350sd
Schoo, I mentioned it to the driveline shop that did my u-bolts for me, and they didn't know of anyone. He gave me a name to a street rod shop, not much help there either. I'm talking back & forth with christurney77 on here about possibly getting a set. Thanks.
Old Jun 15, 2012 | 02:14 PM
schoo's Avatar
schoo
sounds good
roy
Old Jun 17, 2012 | 11:51 AM
loholland's Avatar
loholland
Just take an air grinder with a thin metal cutting wheel and grind a cross in the head and a hammer and chisel will usually cut off the head, then pop them out. If you get them off maybe you or a machine shop that you trust can weld them up and re drill them. Bolt them to the frame with grade 8 bolts.
Old Jun 17, 2012 | 01:32 PM
bigf350sd's Avatar
bigf350sd
Thanks loholland.
Old Jun 19, 2012 | 05:38 PM
bigf350sd's Avatar
bigf350sd
Thanks christurney77, I got the brackets. Now I've gotta find a day to get them on.
Old Jun 20, 2012 | 06:20 AM
christurney77
no problem......
Treacy
Dec 14, 2015 06:56 PM
cyclone-429
Sep 11, 2015 07:43 AM
Dereck
Jun 29, 2013 03:12 PM
andyj ford driver
18
Oct 1, 2011 01:03 PM
NeXtras
15
Feb 9, 2007 12:57 PM
