EGT Why
Old Jun 10, 2012 | 02:45 PM
Utah Jake's Avatar
Utah Jake
EGT Why
So my 2006 6.0 F350 has an Edge tuner. Pulling my 5th wheel up hills it will start flashing a warning at 1300 degrees EGT. Why do I care? Am I in danger of melting something or blowing something up? 1300 degrees is hot to me but is it really all that hot to my exhaust manifold?
Old Jun 10, 2012 | 02:49 PM
djanzen's Avatar
djanzen
Ya it is Hot! 1250 you should back out of the throttle! aluminium melting point is around 1350F and that is the main component in your pistons.
Old Jun 10, 2012 | 04:15 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
A 4" exhaust would help...& the cat delete could help a little.
Old Jun 10, 2012 | 04:27 PM
raytasch's Avatar
raytasch
Believe Nothing
The sole purpose of the pyrometer is to tell you when your exhaust gasses are too hot. The temperature could be measured elsewhere but this is the easiest place to measure the temperatures coming out of the combustion chamber. And like mentioned above, aluminum, as in pistons, starts to change state at 1250 or so. Back out of the throttle or force a downshift to get rpm up or both. Whatever it takes to drop EGTs.
To be blunt, yes you are in danger of blowing the engine.
Old Jun 10, 2012 | 08:08 PM
BLADE35's Avatar
BLADE35
You also can COOK your Turbo
IIRC there is a Piston cooling Jets
Old Jun 10, 2012 | 08:19 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Isn't The turbo cooking the main concern with egt over 1200-1300?
Old Jun 10, 2012 | 08:28 PM
BLADE35's Avatar
BLADE35
Thats how I understood it
And you definatly dont want to shut it down that Hot let it Idel for a few till it cools
Old Jun 11, 2012 | 08:02 AM
npccpartsman's Avatar
npccpartsman
The turbo isn't aluminum on the exhaust side so that isn't really an issue. You'll lose pistons long before you lose a turbo.
relayman53
May 21, 2014 05:44 PM
builttoughf350
6.7L Power Stroke Diesel
Aug 6, 2012 07:47 PM
66fordf100
Nov 26, 2007 05:45 PM
FastCote
Oct 7, 2007 03:43 PM
bigbob37
Sep 19, 2007 10:55 AM
