egt max
Old Sep 18, 2007 | 03:33 PM
bigbob37's Avatar
bigbob37
egt max
I have a 2002 7.3 with a 4" exhaust and intake with a DP tuner, at what EGT should I start getting concerned?
Old Sep 18, 2007 | 03:35 PM
Pocket's Avatar
Pocket
Pre-turbo EGT redline is 1250 degrees. You can exceed that in short bursts, but not for prolonged periods of time or the pistons will melt.
Old Sep 18, 2007 | 03:36 PM
bigbob37's Avatar
bigbob37
thanks I thought it was in that range but wasn't sure
Old Sep 18, 2007 | 07:27 PM
Kwikkordead's Avatar
Kwikkordead
I have a personal rule of thumb when pulling a mountain pass of limiting the EGT to 1150 just to be safe.
Those long WOT pulls can really heat things up!
Old Sep 18, 2007 | 07:34 PM
dpwilson's Avatar
dpwilson
I'm the same as Kwik with coming in under the 1250 most have agreed on. Although I wouldn't be afraid to run 1200-1250 for several minutes. BTW, just got back from the last camping trip of the season and the truck pulled great as usual. Pulled a mountain pass 8% grade for 6 miles with switchbacks every 100 yards and didn't go over 1150 with my 60 hp tow performance tune. Gotta luv the 7.3!!!
Old Sep 18, 2007 | 09:10 PM
kupaa's Avatar
kupaa
how heavy is your trailer?
Old Sep 18, 2007 | 09:34 PM
CSIPSD's Avatar
CSIPSD
I have towed for 30miles or more at 1200-1250... 140k on the motor... Your fine all day at 1250... the pistons never see that temp with the oil jets and fresh air coming in all the time...
Ever jump in a cummins and try to keep it under 1250... there pistons dont melt do they...
Old Sep 18, 2007 | 09:59 PM
dpwilson's Avatar
dpwilson
about 6500 for trailer. Fully loaded I'm around 8k. Hoping for a new 5th wheel in the near future. Either that or a new rugrat, should be fun either way.
Old Sep 19, 2007 | 12:35 AM
Kwikkordead
WOW, what pass was that?
Last time I was out I pulled over Cedar Breaks pass, it crested at 9900 or so feet and I was down into third gear and 35 mph on that one. Too steep for fourth, even. The EGT's were way down on that pull because I didn't have to WOT the engine going that slow. I don't remember what they were, but it was well below the red zone, I remember that.
Had a long line of cars behind me at the top too.
Old Sep 19, 2007 | 08:37 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Amen, brotha!!
Those Cummins do like to make some heat. However, they also like to make lots of boost and that comes from having a severely undersized turbine housing.
Old Sep 19, 2007 | 08:49 AM
Kwikkordead
Do they have steel pistons?
Old Sep 19, 2007 | 09:13 AM
just another truck's Avatar
just another truck
Just remember, the Rugrat is is more expensive in the long run, but a hell of alot more fun!!
Old Sep 19, 2007 | 10:55 AM
jtharvey's Avatar
jtharvey
You're not kidding. My buddies Dodge that I work on can hit anywhere from 1400*-1700* with ease, and it can hold 52 psi of boost in top gear. That's with nothing but simple bolt-ons too, like TST box, turbo, and IC...we haven't even touched the injectors yet. I keep trying to tell him he needs head studs next before he blows a headgasket, but his mind is pretty set on a water/meth kit. Needless to say, I'm not looking foward to replacing that headgasket.
Back on topic, if I were towing up a long grade for several minutes, I'd keep it around 1200. If you're running a 1/4 mile drag race, or doing a sled pull, I wouldn't even worry about looking at the gauge. There are a good number of Powerstrokes with stock pistons who are drag racing and pulling that have no problems, and they are well exceeding the suggested 1250 redline. I think mech has said his pyro is pegged past 1600 at the end of a pull. I don't think the 10-15 seconds of high heat during a race or pull is enough time to even come close to heat soaking the pistons and causing damage.
