steering wheel removal
Old Jun 10, 2012 | 02:25 PM
winemaker69's Avatar
winemaker69
I need to remove my steering wheel to replace some parts inside of the column. How is the face plate removed? I have cruise on my 86 F 250. Thanks to all who respond.
Old Jun 10, 2012 | 02:41 PM
Franklin2's Avatar
Franklin2
Should be two screws on the rear cluster side of the wheel. That will take the pad/face off. Then you have a big nut to take loose, and then you will need a puller to pull the wheel off. They sell them in the parts stores, or you can measure the distance between the holes and see if a harmonic balancer puller will work. There are two threaded holes in the wheel that you thread long bolts into to pull it off. I think I have used my harmonic balancer puller to do this, but I had to go get two bolts to fit the holes.
Old Jun 10, 2012 | 05:05 PM
Gary Lewis's Avatar
Gary Lewis
I just use a small gear puller with the legs under the heads of bolts that screw into those holes. But, on the 81 the shaft didn't have a center "dent" for the puller's bolt to center in, so I drilled a shallow hole there so it wouldn't walk and so it wouldn't mushroom the shaft any. And, by the way, they are 5/16-24 bolts.
tinman52
24
Mar 8, 2015 07:13 PM
rocknrod
1997 - 2003 F150
Mar 13, 2014 09:06 PM
reddogforge
Jun 14, 2010 04:23 PM
Witty73
Apr 16, 2010 06:27 AM
Lemonjello
1978 - 1996 Big Bronco
Oct 17, 2004 09:12 AM
