Floating gages
Also, I had a spare starter cable, black, and ran that direct from battery negative to the firewall using one of the hinge mounting bolts.
Next to fix the wiring mess with the trailer harness and block to frame ground cable.
Wife just asked me why I am working on Blue so much. I had to tell her the same story above. Again. She has heard it before. And no she is not blond, but sometimes acts it.
As for the wife, no comment. Not healthy or smart to comment on someone's spouse in a situation like that.
She knows she is. It's all good.
I got bored and decided to finally look up some of the codes on my ID plate.
Seems my truck was built at Michigan Truck for a Detroit dealer. How it got to the West Coast... I doubt Carfax can give me any history.
Can anyone tell me what the rest of this means?
Looks like:
FO 126 ?
TO 494 ?
48 - Detroit DSO
C 8 ?
I know this is an offshoot of the thread, and I will get back to the orig purpose. I promise.
And since I brought up Carfax, I got one.
Built in Detroit and shipped to Alaska and was there from 1982 until 1996, then down to Washington for 3 years and back to Alaska. Then sometime around 2003 it came to Washington. Reported stolen in 2004 and recovered 2 days later. Moved to 20 miles from my house from 2005 til 2010. I am the third owner. The second owner had it for 2 months.
Wonder if there is a way to look up the original Alaska title. I have the number....
FXXXXX represents front axle accessory reserve capacity
TXXXXX represents total accessory reserve capacity
The C8 is in the "Suspension Identification codes" area and represents Aux/Optional usage codes for the springs. Don't know what the C8 actually means though.
What Section/page number of your book are those interpretations stated on? You're talking about the Body/Chassis/Electrical book, correct? Could you take a picture and post it?
I have the 1981 version and should (might) be able to find it there, too, but I have never heard of an "accessory reserve capacity" much less such a thing written on a Certification Label and would like to look it up, thanks.
In my books, Ford hadn't begun putting Spring & Tape codes on the cert label until sometime in the mid-1980s but I forget exactly when. My 1981 doesn't have that stuff.
The Spring Codes on the later labels give only front & rear codes - Front Springs = C, Rear Springs = 8 (but your label doesn't have that stuff).
I've never seen anything about auxiliary or optional usage or anything about Suspension Identification Codes, where are you finding this documented? What book and page number? Yours is a 1982 model, correct?
How bizarre,thanks for posting that!
From the looks of stangrcr's 1982 book..., and with the info from my book that states it's a DSO code...
Those F and T codes are in the DSO space and affects the special order options and accessories that can be installed.
F0126 = 126 lbs in reserve weight that can be added in accessories to the front.
T0494 = 494 lbs in total reserve weight.
Presumably this affects Dealer options or aftermarket accessories.
IE: If you get a plow that's over 126 lbs etc.. you can't install it on that vehicle.
Presumably this affects Dealer options or aftermarket accUessories.
Buying it over the counter would be ok, however legally you wouldn't be able to install it either. It's one of those... "If you get in a wreck, the insurance company has a loophole not to pay" type situations. Doesn't stop people 99.9% of the time installing stuff though...
