Sponsored by: Real Truck
Clunking
Old Jun 9, 2012 | 12:56 AM
08 superduty's Avatar
08 superduty
Clunking
I have a 2008 v10 f250 crew cab longed. I was wondering if anybody can tell me why when I come to a stop and the rear off the truck settles it clunks. Then when I take off it does it again. It doesn't do it every time either. It will also do it even after the truck is already rolling under it's own power and I give it gas.
Old Jun 9, 2012 | 02:01 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Slip joint? Rear diff? Just guesses here.
Old Jun 9, 2012 | 02:19 AM
08 superduty
I will check those out. Thanks
Old Jun 9, 2012 | 05:59 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's a common problem. The driveshaft slip joint needs lube. Ford sells a lube specifically for this. Nothing else seems to last very long in the slip joint.
Old Jun 9, 2012 | 07:22 AM
drey04's Avatar
drey04
I agree on the slip joint. I had to grease mine up about 2 months ago.
Old Jun 9, 2012 | 08:43 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
Sounds like the slip joint like said. Here is how to do this. Slip joint regreasing
Old Jun 9, 2012 | 10:13 AM
08 superduty
Thanks I will try this
Old Jun 16, 2012 | 09:17 PM
08 superduty
Do you have to use a special socket for the rear driveline bolts
Old Jun 16, 2012 | 10:18 PM
redford's Avatar
redford
FTE Leadership Emeritus
No, just an 8mm combo wrench or maybe a deep socket.
Vijay
15
May 28, 2014 04:49 PM
jamie7375
Mar 10, 2009 09:07 PM
nightskyisme
May 13, 2007 10:07 AM
alz
Feb 19, 2007 06:38 AM
