Screeching sound from engine area!
Old Jun 9, 2012 | 07:36 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Originally Posted by dbdbb
I would say you should also load test your battery, sounds like it is drawing a lot of load from your alt., very possible it is fine but could possibly have an internal problem.
I have a 94 Mustang with a 460 swapped in but I retained the original Alt. and serpentine belt, it also squeals when first started but goes away after a couple of seconds.
Agree with this. A good battery at full charge should not put much load on the alternator.
Old Jun 9, 2012 | 10:08 AM
drizzie27's Avatar
drizzie27
So how do you do a load test on TE battery?
Old Jun 9, 2012 | 10:16 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Don't understand the "TE" part, but any auto parts store can load test a battery. It has to be fully charged to test, so they may have to charge first if it's down.
Old Jun 9, 2012 | 10:32 AM
drizzie27's Avatar
drizzie27
I meant "the" stupid iPhone
Old Jun 9, 2012 | 10:46 AM
orich's Avatar
orich
A warn pulley can cause squeals also as the inner sides touch the pulley gets a mirror glaze and the belt not grabbing hold when unload. I had this problem until, I re-dressed the v-grove on my high speed wire wheel/grinder braking the glaze was a fix for me. I did all pulleys when doing the harden seat valve job back in 1995. A glazed belt will slip, The wrong size belt not fitting correctly into the v-pulley. Or like O/P said a lose belt. A Lot of guys don't know how much to tighten a belt is mostly the problem too..
orich
Peace2Peep
Mar 18, 2016 11:02 PM
Mixer man
6.4L Power Stroke Diesel
Mar 7, 2016 11:13 AM
Ranger_CN78
1983 - 2012 Ranger & B-Series
Dec 15, 2003 06:34 PM
dakejh
Sep 15, 2003 11:44 PM
FordCowboy2000
1997 - 2003 F150
Jul 17, 2003 12:09 PM
