Chirping sound
Old Sep 15, 2003 | 03:18 PM
dakejh's Avatar
dakejh
Chirping sound
A couple of weeks ago my cam position sensor was replaced. Since then, I get a high piched sound in the front of my engine. I do not know if they are related. It sounds like barrings on the altinator or other component is going bad, but when I remove the belt, all spins fine without any noise or roughness. Any ideas?
Old Sep 15, 2003 | 07:25 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Chirping sound
Does it just chirp when you turn it off or when you have it running? Or both?
Old Sep 15, 2003 | 07:36 PM
cgl's Avatar
cgl
Chirping sound
I'd say it's your fan belt. Mine did that when it was new, which the dealer replaced the belt. And my neighbor's did it too. I believe there was a TSB out on this..... but I'll have to re-check to be sure.
Old Sep 15, 2003 | 07:40 PM
dakejh's Avatar
dakejh
Chirping sound
It is not when I shut it off. Its a constant, sometimes going away for a while. It sounds almost like metalic(metal sliding by metal). No performance changes. It does not sound loud or anything. Just in there with the rest of the engine noise. It does seem to speed up with RPMs. I will change my belt and see what happens.
Old Sep 15, 2003 | 07:46 PM
Toreador_Diesel
Chirping sound
I'd go with what cgl said and change the belt. If anything, that should fix it.
Old Sep 15, 2003 | 09:10 PM
johnsdiesel's Avatar
johnsdiesel
Chirping sound
They probably took the belt off to replace the CMP sensor.
Old Sep 15, 2003 | 09:46 PM
RRMike's Avatar
RRMike
Chirping sound
Sounds like a wasted water pump to me. They have a metallic chirping sound when the bearings go bad.
Old Sep 15, 2003 | 11:00 PM
dakejh's Avatar
dakejh
Chirping sound
The water pump?
Would I feel it if i spin it with a cool engine? Because all my investigating points to that area of the truck......It is hard to localize. As you know the engine is pretty noisy on the good days.LOL. Thanks, I will look at changing the belt and checking the water pump.
Old Sep 15, 2003 | 11:44 PM
RRMike's Avatar
RRMike
Chirping sound
When you have the belt off check for play in the water pump shaft. (side to side or up and down) That's your indicator.
zachbrown0413
2004 - 2008 F150
Nov 6, 2014 07:17 PM
07 F250 Aggie Mobile
6.7L Power Stroke Diesel
Jun 25, 2013 03:27 AM
F 250 6 liter
Jun 15, 2010 07:08 PM
cklecker
37
Jan 13, 2010 03:19 PM
