Help - Distributor Install hitting rod
Old Jun 7, 2012 | 07:11 PM
Atlasts's Avatar
Atlasts
I'm trying to get my distributor back in my 1965 352 - There is a rod in the engine block that the end of the distributor slides over.
My problem is the rod is leaning against the side of the hole so the distributor end will not slide over it. I was lucky and got it over one time but now that I'm ready to install it, it won't seat over the rod.
I there a trick to getting that rod to be centered in the hole so the distributor end will slide over it?
Old Jun 7, 2012 | 08:03 PM
Buzz44's Avatar
Buzz44
I think I just put a slug of grease down there to hold the oil pump drive shaft centered in the hole. I used white lithium grease. Not to much just enough to hold it centered.
Old Jun 7, 2012 | 10:01 PM
puttster's Avatar
puttster
Good answer, vic.
Old Jun 7, 2012 | 10:16 PM
critterf1's Avatar
critterf1
Put slight downward pressure on the vacuum advance while somebody bumps the engine over, it'll fall right in.
Old Jun 8, 2012 | 08:22 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
X2 - sounds like the teeth on the cam and the flats on the drive shaft aren't in the exact-right spot.
Old Jun 8, 2012 | 08:31 AM
Argess's Avatar
Argess
x3
It's not the rod leaning to the side, it's alignment of the hex shape of the rod to the hex hole in the end of the distributor.
The rod (oil pump drive shaft) is normally pointed a bit so it will center when installing the distributor, but the hex needs to line up, and you do that as stated above... downward pressure on the distributor and crank the engine.
Old Jun 8, 2012 | 05:11 PM
Atlasts's Avatar
Atlasts
Thanks for the info. The turnover over of the motor let it drop over the oil pump shaft!
Old Jun 8, 2012 | 07:08 PM
krewat's Avatar
krewat
Excellent! Now keep that FE running
Old Dec 10, 2020 | 04:55 PM
dennisnky's Avatar
dennisnky
Trailering
I actually just now did this. Didn't have another person who could push down on the distributor but I put a 5lb weight on it and just turned the key like 0.1 seconds and it dropped.
Thanks!
Doogievlg
Jun 3, 2015 01:50 PM
Schlurch
May 7, 2014 06:28 PM
rogerf100
15
Feb 21, 2007 02:04 AM
imlowr2
Jul 15, 2004 02:20 PM
eandaauto
Jun 1, 2004 11:17 PM
