2002 Ford F350 Suddenly Stopped Pulling
Thank you Mark and Cord812 for your insight and experience on this matter. @ Mark: So as the torque converter "grows" the "flexplate" allows movement to keep the crankshaft "centered" on it's thrust bearings? Is there a chance that an aftermarket torque converter is not compatible with this "flexplate". Banks Engineering is supposed to have developed this torque converter to work within Ford specs. If the flex action is relieving stress against the thrust bearings is there a chance it is overloading the tranny in some way? If this were your tranny and you were rebuilding it would you consider a return to a stock Ford TC? One more question: The Banks variable electronic stall control was recently removed from the vehicle. Did that render the default specs on this system moot? I know this sounds like a silly question but the aftermarket tc is supposed to be subject to Ford specs at the low setting and I have felt for some time that it was engaging at a higher stall than stock.
Typically aftermarket converters are not subject to any of Ford's specs. They design whatever they want. Most of the time the converters are made from stronger materials than the stock converter, so they will grow less than the stock converter.
I had my tranny rebuilt with HD internals and a split overdrive.
I can go back through my old emails if you want the brands and details on it but the guy warrantied the tranny for 36K miles and 2yrs. so long as I didn't breach the 500HP range. $2500 for the pacage... I'm not gonna complain.
Only reason I had to get the info emailed was to get my chip reburned.
As for why.... My tranny was the original and died at about 240K miles. I figured with the abuse it took from hauling...it was about time anyway. When the shop called me they asked if I thing for Chia pets. The drain plug had so many fragments that it looked like a chia pet.
2002 F 350 suddenly stopped pulling after I stopped at stop sign.160K miles. 7.3 w/AT. Had to rev up for slow roll.Truck would barely roll as though brakes were on or It would suddenly engage and seem to be working right, as though the torque converter wasn't locking up. Am using a Banks torque converter. Tried to reverse, made strange clacking noise and jumped around. Drove forward and reverse, "clacking" stopped, started making grinding noise like brakes. Checked brakes. Fairly new and operating properly. Suspect center carrier bearing. Some up and down slack. Tranny fluid is full and clean,
https://www.ford-trucks.com/forums/1...l#post11921851
Kind of an additional half gear. When I hit about 50 when accellerating normally, it kicks into OD. At 70, my RPMs are about 2000... When I hit about 75 @ 2500... The RPMS drop back down to 2000. Not a lot of change..but enough to give me a touch more MPGs. At least thats what I call a split OD. Could be doing something with the TC... I'm not a tranny wiz...which is why I paid to have mine done and didn't mess with it...Much. Other than trying all gears when it died just to see what I had and didn't have.
Interesting theory, but it's wrong.
Ford calls it a flexplate. You may call it a flywheel if you like.
It is made to flex, hence the name. As the torque converter spins at higher speeds it grows. It grows both axially and radially. The radial growth doesn't cause any problems, but the axial growth would react against the crankshaft unless the flex plate were able to absorb this force. It does this by flexing in the axial direction. If it didn't the force the torque converter would exert on the crankshaft would result in an early failure of the engine's thrust bearings.
I didn't know it got the name flex plate due to it actually flexing or growing. I've heard of flex plates being cryo'd. Is this a good idea? I'm assuming this is done to keep them from cracking or breaking.
Drake
