66 f100 update
Old Jul 17, 2012 | 04:07 PM
forddude66's Avatar
forddude66
Every thing is new except the flywheel but it was resurfaced. Ive looked a few things up online and people were saying that some clutches will chatter for a few hundred miles and im like "what?!" We got all the clutch parts from lmc and we arent sure weather the pressure plate is new or remanufactured though.
Old Jul 29, 2012 | 08:43 AM
F&M's Avatar
F&M
Wow..nice truck! Just a thought..you might want to check the pilot bearing also for your clutch chatter.
Old Jul 29, 2012 | 10:03 AM
rogue40's Avatar
rogue40
I've never heard of a chattering issue with a properly installed new clutch(and believe me, I am the formost expert on doing things wrong!).
Parts wear out together and work fine in a balance of sorts but, when you replace some of the components, it can bring other issues to light.
Did you have the transmission input shaft bearing checked? Every vehicle I ever had that chattered like that had either the pilot bushing, input shaft bushing or both going out.
Old Jul 29, 2012 | 01:17 PM
forddude66's Avatar
forddude66
Every peice of the drivetrain is brand new. Obviously the engine, the transmission was completely rebuilt, all new clutch stuff and the drive shaft was rebuilt. The only thing that has not been touched yet is the rear axel
Old Jul 29, 2012 | 02:16 PM
F&M's Avatar
F&M
I think the rear end IS part of the drive train! You might check for a sloppy pinion shaft then. Perhaps it's bad and it seems like clutch chatter.It could be bucking around on you and traveling through the drive shaft to make you think it's the clutch.Just trying to help.That wear pattern is important for smoooth-ness!!
Old Jul 29, 2012 | 04:10 PM
jacks61ford's Avatar
jacks61ford
worn cab mounts?
Old Jul 29, 2012 | 04:25 PM
forddude66's Avatar
forddude66
I appreciat the suggestions guys. Ive heard several things that say some clutches do chatter for a little and i honestly dont know what to beleive. This is definately chatter though there is no doubt about it. It only does it when the clutch slips. I dont really have as much of a problem with it as my dad. I drove it 5 miles down town last week without it doing it at all because i dont slip the clutch like my dad. We were gonna see if it settled down buy about 500 miles and if it hasnt we will be replaceing stuff.
Old Jul 29, 2012 | 07:52 PM
forddude66's Avatar
forddude66
We are actually haveing a bigger problem right now because the battery is new, the alternator has been tested and was perfectly fine, and the voltage regulator is brand new yet when i hook up a voltmeter it says it has 12.6 volts off, idleing it has 12.4 and then when i tuned it back off it had 12.5. What do you guys think?
Old Aug 2, 2012 | 12:24 AM
forddude66's Avatar
forddude66
I am haveing another battery chargeing system problem with our 1968 ford fairlane 500. We have a brand new battery in it. We havent been driveing it as much as usual but i put a volt meter on it today and it had 11.9 volts. I started it up somehow and looked and the voltage was normal, so i know the alternator is good. Since the wireing for these cars is almost identical to the trucks, i was hopeing someone could help me figure out what is drawing on the battery
DBANDGB
2009 - 2014 F150
Nov 3, 2013 10:24 AM
Vinford
Oct 22, 2012 08:12 AM
Corner Gas
May 7, 2008 05:36 PM
jrhix
Aug 6, 2003 04:35 PM
390fe
13
Jan 24, 2002 03:28 PM
